Jetson TX2 Architecture: aarch64 can not install jetpack2
To nvidia.
     Error: Jetpack must be run on x86_64 host platform.
Please advise.
Try JetPack 3.0?
Yes i try JetPack3.0 new release.Error tell me that architecture must be x86_64 only.But i buy
new Jetson TX2 use command $ uname -a
it shown aarch64 aarch64 aarch64 GNU/Linux.
Are you running the installer directly on the TX2? If so, that’s not the correct way to do it. You need to run the installer on the Host machine (an Ubuntu 14.04 system that’s connected to the same network switch as the TX2). The installer is for x86_64 architectures.
