I am getting an error that it cant install on the aarm64 processor any help would be greatly appreciated.
thank you,
joe
thank you,
joe
It is unclear what error you are seeing…May you elaborate more for better advices ?
Error: Jetpack must be run on x86_x64 host platform. Detected aarch64 platform. I downloaded what was reccomeneded but still getting this error
JetPack is run on a desktop Ubuntu PC, not the Jetson. If flashing, the Jetson will start in recovery mode and the micro-B USB cable connected. If just installing packages, then the wired ethernet will be connected. A Jetson cannot self-flash.
