I have downloaded tmp468 driver code form gitlab. Now i want to intergarte this driver code externally (out of device tree module). I want to read data from a specific i2c bus register address on which tmp468 temperature sensor is mounted. Could you plese help me finding the exact solution to acheive this?
Integating and bringing up TMP468 temperature sensor driver code on Jetson xavier NX reference board
hello ekta.singh,
may I know what’s your pin connections, are you using the 40-pin expansion header?
according to NVIDIA Jetson Xavier NX GPIO Header Pinout - JetsonHacks, it’s i2c bus 8 for pin-3/pin5; and i2c bus 1 for pin-27/pin-28.
please have a try to execute i2cdetect
and sharing the results.
