Interesting problem for use opencv in dsexample
**• Hardware Platform (Jetson / GPU)GPU
**• DeepStream Version6.1
**• TensorRT Version8.4
**• NVIDIA GPU Driver Version (valid for GPU only)450
Dear professor:
I meet an interesting problem. I use opencv4 in dsexample. If I define a Mat in function of “gst_fenceplugin_ip”, the app will broken down after processing several frames . The error information is : Segmentation fault(core dumped)
But if I move the Mat define into the function " get_converted_mat", it is normal.
Could you please tell me why I can not use the cv:: Mat mydata, in function “gst_fenceplugin_ip”. Thank you very much
could you share the simple code to reproduce?
Thank you for your response. I find the problem coming from my code. That I write a plugin by myself. But I do not have solved this problem.
https://forums.developer.nvidia.com/t/i-draw-lines-in-dsexample-and-how-to-save-the-frame-with-that-lines/217755/3
