I retrained the detect model (ssd-mobilenet-v2) with my own dataset and s…uccessfully converted it to ONNX and now trying to run it on Jetson Nano 4G kit.
I used this command:
`./detectnet --model=/home/jetson/detect/mb2-ssd-lite.onnx --input-blob=input_0 --output-blob=boxes --output-cvg=scores --input_URI /home/jetson/detect/test6.mp4 --input-codec=mpeg4 --log-file=/home/jetson/detect/detectNet-Log.txt --debug --log-level=debug --headless`
and got this error:
[TRT] ------------------------------------------------
[TRT] Timing Report /home/jetson/detect/mb2-ssd-lite.onnx
[0;31m[cuda] device not ready (error 600) (hex 0x258)
[0m[0;31m[cuda] /home/jetson/detect/AI/jetson-inference/build/aarch64/include/jetson-inference/tensorNet.h:685
[0m[TRT] Pre-Process CPU 0.09969ms CUDA 0.00000ms
[0;31m[cuda] invalid resource handle (error 400) (hex 0x190)
[0m[TRT] Network CPU 0.00000ms CUDA 0.00000ms
[TRT] Total CPU 0.09969ms CUDA 0.00000ms
[gstreamer] gstDecoder -- recieved 1280x720 frame (1382400 bytes)
[0;31m[TRT] ../rtSafe/cuda/cutensorReformat.cpp (352) - cuTensor Error in executeCutensor: 7 (Internal cuTensor reformat failed)
[0m[0;31m[TRT] FAILED_EXECUTION: std::exception
[0m[0;31m[TRT] failed to execute TensorRT context on device GPU
[0m[TRT] ------------------------------------------------
[0m[TRT] Pre-Process CPU 0.05813ms CUDA 0.00000ms
[TRT] Total CPU 0.05813ms CUDA 0.00000ms
If I remove the `--headless` option the video will be displayed but no inference on the video.
Full log is:
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstDecoder -- creating decoder for /home/jetson/detect/test6.mp4
[gstreamer] gstDecoder -- discovered video resolution: 1280x720 (framerate 30.000000 Hz)
[gstreamer] gstDecoder -- discovered video caps: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)main, width=(int)1280, height=(int)720, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
[gstreamer] gstDecoder -- pipeline string:
[gstreamer] filesrc location=/home/jetson/detect/test6.mp4 ! qtdemux ! queue ! h264parse ! omxh264dec ! video/x-raw ! appsink name=mysink
[0;32m[video] created gstDecoder from file:///home/jetson/detect/test6.mp4
[0m------------------------------------------------
gstDecoder video options:
-- URI: file:///home/jetson/detect/test6.mp4
- protocol: file
- extension: mp4
-- deviceType: file
-- ioType: input
-- codec: h264
-- width: 1280
-- height: 720
-- frameRate: 30.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
[0;31m[video] videoOptions -- failed to parse output resource URI (null)
[0m[0;31m[video] videoOutput -- failed to parse command line options
[0m[0;31mdetectnet: failed to create output stream
[0m
detectNet -- loading detection network model from:
-- prototxt NULL
-- model /home/jetson/detect/mb2-ssd-lite.onnx
-- input_blob 'input_0'
-- output_cvg 'NULL'
-- output_bbox 'boxes'
-- mean_pixel 0.000000
-- mean_binary NULL
-- class_labels NULL
-- threshold 0.500000
-- batch_size 1
[TRT] TensorRT version 7.1.3
[TRT] loading NVIDIA plugins...
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[0;31m[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[0m[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] detected model format - ONNX (extension '.onnx')
[TRT] desired precision specified for GPU: FASTEST
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /home/jetson/detect/mb2-ssd-lite.onnx.1.1.7103.GPU.FP16.engine
[TRT] loading network plan from engine cache... /home/jetson/detect/mb2-ssd-lite.onnx.1.1.7103.GPU.FP16.engine
[0;32m[TRT] device GPU, loaded /home/jetson/detect/mb2-ssd-lite.onnx
[0m[TRT] Deserialize required 2829932 microseconds.
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] -- layers 144
[TRT] -- maxBatchSize 1
[TRT] -- workspace 0
[TRT] -- deviceMemory 20514816
[TRT] -- bindings 3
[TRT] binding 0
-- index 0
-- name 'input_0'
-- type FP32
-- in/out INPUT
-- # dims 4
-- dim #0 1 (SPATIAL)
-- dim #1 3 (SPATIAL)
-- dim #2 300 (SPATIAL)
-- dim #3 300 (SPATIAL)
[TRT] binding 1
-- index 1
-- name 'scores'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #1 3000 (SPATIAL)
-- dim #2 8 (SPATIAL)
[TRT] binding 2
-- index 2
-- name 'boxes'
-- type FP32
-- in/out OUTPUT
-- # dims 3
-- dim #2 4 (SPATIAL)
[TRT]
[TRT] binding to input 0 input_0 binding index: 0
[TRT] binding to input 0 input_0 dims (b=1 c=3 h=300 w=300) size=1080000
[cuda] cudaAllocMapped 1080000 bytes, CPU 0x100e60000 GPU 0x100e60000
[TRT] binding to output 0 boxes binding index: 2
[TRT] binding to output 0 boxes dims (b=1 c=3000 h=4 w=1) size=48000
[cuda] cudaAllocMapped 48000 bytes, CPU 0x100d60200 GPU 0x100d60200
[TRT]
[0;32m[TRT] device GPU, /home/jetson/detect/mb2-ssd-lite.onnx initialized.
[0m[TRT] detectNet -- number object classes: 4
[TRT] detectNet -- maximum bounding boxes: 3000
[cuda] cudaAllocMapped 1344000 bytes, CPU 0x100f68000 GPU 0x100f68000
[cuda] cudaAllocMapped 64 bytes, CPU 0x100d6be00 GPU 0x100d6be00
[gstreamer] opening gstDecoder for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from NULL to READY ==> h264parse1
[gstreamer] gstreamer changed state from NULL to READY ==> queue0
[gstreamer] gstreamer changed state from NULL to READY ==> qtdemux1
[gstreamer] gstreamer changed state from NULL to READY ==> filesrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> h264parse1
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> queue0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer stream status CREATE ==> sink
[gstreamer] gstreamer changed state from READY to PAUSED ==> qtdemux1
[gstreamer] gstreamer changed state from READY to PAUSED ==> filesrc0
[gstreamer] gstDecoder -- onPreroll()
[gstreamer] gstreamer stream status ENTER ==> sink
[gstreamer] gstreamer message stream-start ==> pipeline0
[gstreamer] gstreamer message duration-changed ==> h264parse1
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ /\ AVC";
[gstreamer] gstreamer mysink taglist, datetime=(datetime)2018-04-22T07:30:53Z, private-qt-tag=(sample){ 00000019677373740000001164617461000000010000000030:None:R3N0U2VnbWVudCwgZmxhZ3M9KEdzdFNlZ21lbnRGbGFncylHU1RfU0VHTUVOVF9GTEFHX05PTkUsIHJhdGU9KGRvdWJsZSkxLCBhcHBsaWVkLXJhdGU9KGRvdWJsZSkxLCBmb3JtYXQ9KEdzdEZvcm1hdClHU1RfRk9STUFUX1RJTUUsIGJhc2U9KGd1aW50NjQpMCwgb2Zmc2V0PShndWludDY0KTAsIHN0YXJ0PShndWludDY0KTAsIHN0b3A9KGd1aW50NjQpMTg0NDY3NDQwNzM3MDk1NTE2MTUsIHRpbWU9KGd1aW50NjQpMCwgcG9zaXRpb249KGd1aW50NjQpMCwgZHVyYXRpb249KGd1aW50NjQpMTg0NDY3NDQwNzM3MDk1NTE2MTU7AA__:YXBwbGljYXRpb24veC1nc3QtcXQtZ3NzdC10YWcsIHN0eWxlPShzdHJpbmcpaXR1bmVzOwA_, 0000001f677374640000001764617461000000010000000032313636393535:None:R3N0U2VnbWVudCwgZmxhZ3M9KEdzdFNlZ21lbnRGbGFncylHU1RfU0VHTUVOVF9GTEFHX05PTkUsIHJhdGU9KGRvdWJsZSkxLCBhcHBsaWVkLXJhdGU9KGRvdWJsZSkxLCBmb3JtYXQ9KEdzdEZvcm1hdClHU1RfRk9STUFUX1RJTUUsIGJhc2U9KGd1aW50NjQpMCwgb2Zmc2V0PShndWludDY0KTAsIHN0YXJ0PShndWludDY0KTAsIHN0b3A9KGd1aW50NjQpMTg0NDY3NDQwNzM3MDk1NTE2MTUsIHRpbWU9KGd1aW50NjQpMCwgcG9zaXRpb249KGd1aW50NjQpMCwgZHVyYXRpb249KGd1aW50NjQpMTg0NDY3NDQwNzM3MDk1NTE2MTU7AA__:YXBwbGljYXRpb24veC1nc3QtcXQtZ3N0ZC10YWcsIHN0eWxlPShzdHJpbmcpaXR1bmVzOwA_ }, container-format=(string)"ISO\ MP4/M4A";
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)";
[gstreamer] gstDecoder recieve caps: video/x-raw, format=(string)NV12, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)30/1
[gstreamer] gstDecoder -- recieved first frame, codec=h264 format=nv12 width=1280 height=720 size=1382400
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x1010b1000 GPU 0x1010b1000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x101203000 GPU 0x101203000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x101355000 GPU 0x101355000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x1014a7000 GPU 0x1014a7000
RingBuffer -- allocated 4 buffers (1382400 bytes each, 5529600 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> h264parse1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> queue0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> qtdemux1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> filesrc0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda] cudaAllocMapped 2764800 bytes, CPU 0x1015f9000 GPU 0x1015f9000
[cuda] cudaAllocMapped 2764800 bytes, CPU 0x10189c000 GPU 0x10189c000
[cuda] cudaAllocMapped 2764800 bytes, CPU 0x101b3f000 GPU 0x101b3f000
[cuda] cudaAllocMapped 2764800 bytes, CPU 0x101de2000 GPU 0x101de2000
RingBuffer -- allocated 4 buffers (2764800 bytes each, 11059200 bytes total)
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)3441840, maximum-bitrate=(uint)3441840, bitrate=(uint)2974128;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1334400, maximum-bitrate=(uint)3441840, bitrate=(uint)2825061;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1267920, maximum-bitrate=(uint)3441840, bitrate=(uint)2695300;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1267920, maximum-bitrate=(uint)3764880, bitrate=(uint)2777575;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1267920, maximum-bitrate=(uint)3764880, bitrate=(uint)2672468;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3764880, bitrate=(uint)2577008;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3764880, bitrate=(uint)2632665;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3764880, bitrate=(uint)2555802;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3764880, bitrate=(uint)2484400;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3764880, bitrate=(uint)2426640;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3843120, bitrate=(uint)2491025;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3843120, bitrate=(uint)2438786;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1240560, maximum-bitrate=(uint)3843600, bitrate=(uint)2456482;
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1201680, maximum-bitrate=(uint)3843600, bitrate=(uint)2414656;
[0m
[TRT] Pre-Process CPU 0.06526ms CUDA 3.22250ms
[0m[0;31m[cuda] home/jetson/detect/jetson-inference/build/aarch64/include/jetson-inference/tensorNet.h:685
[TRT] Total CPU 0.06526ms CUDA 3.22250ms
[0;33m[TRT] note -- when processing a single image, run 'sudo jetson_clocks' before
to disable DVFS for more accurate profiling/timing measurements
[0m[0;31m[TRT] ../rtSafe/cuda/cutensorReformat.cpp (352) - cuTensor Error in executeCutensor: 7 (Internal cuTensor reformat failed)
[0m
[TRT] Pre-Process CPU 0.06438ms CUDA 1.32266ms
[TRT] Total CPU 0.06438ms CUDA 1.32266ms
And here is the log from python `detect-net.py` with the same arguments
CUTENSOR ERROR: some argument is NULL.
File "detectnet.py", line 63, in <module>
[gstreamer] gstreamer mysink taglist, video-codec=(string)"H.264\ \(Main\ Profile\)", minimum-bitrate=(uint)1201680, maximum-bitrate=(uint)3843600, bitrate=(uint)2365026;
detections = net.Detect(img, overlay=opt.overlay)
Exception: jetson.inference -- detectNet.Detect() encountered an error classifying the image
PyTensorNet_Dealloc()
jetson.utils -- PyVideoSource_Dealloc()
[gstreamer] gstDecoder -- stopping pipeline, transitioning to GST_STATE_NULL
[gstreamer] gstreamer changed state from PLAYING to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from PLAYING to PAUSED ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from PLAYING to PAUSED ==> h264parse1
[gstreamer] gstreamer changed state from PLAYING to PAUSED ==> queue0
[gstreamer] gstreamer changed state from PLAYING to PAUSED ==> qtdemux1
[gstreamer] gstreamer changed state from PLAYING to PAUSED ==> filesrc0
[gstreamer] gstreamer changed state from PLAYING to PAUSED ==> pipeline0
[gstreamer] gstDecoder -- pipeline stopped
jetson.utils -- PyVideoOutput_Dealloc()
jetson.utils -- PyCudaMemory_Dealloc()
I also attached the log file and model file for your reference.
[detectNet-Log.txt](https://github.com/dusty-nv/jetson-inference/files/5544082/detectNet-Log.txt)
**Update:
I ran the command `/usr/src/tensorrt/bin/trtexec --onnx=/home/jetson/detect/mb2-ssd-lite.onnx --verbose` and got output PASS
[mb2-ssd-lite.zip](https://github.com/dusty-nv/jetson-inference/files/5544435/mb2-ssd-lite.zip)
[11/16/2020-13:15:29] [I] Starting inference threads
[11/16/2020-13:15:32] [I] Warmup completed 5 queries over 200 ms
[11/16/2020-13:15:32] [I] Timing trace has 123 queries over 3.07144 s
[11/16/2020-13:15:32] [I] Trace averages of 10 runs:
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 28.9624 ms - Host latency: 29.1034 ms (end to end 29.1151 ms, enqueue 7.66055 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.3881 ms - Host latency: 24.5172 ms (end to end 24.5276 ms, enqueue 10.1836 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4319 ms - Host latency: 24.5609 ms (end to end 24.5718 ms, enqueue 6.74628 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4466 ms - Host latency: 24.5759 ms (end to end 24.5864 ms, enqueue 8.47657 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4543 ms - Host latency: 24.5837 ms (end to end 24.5945 ms, enqueue 6.29825 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4601 ms - Host latency: 24.5901 ms (end to end 24.6006 ms, enqueue 6.54089 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4666 ms - Host latency: 24.5964 ms (end to end 24.6071 ms, enqueue 7.14116 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4557 ms - Host latency: 24.5844 ms (end to end 24.5947 ms, enqueue 6.34243 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4625 ms - Host latency: 24.5919 ms (end to end 24.6027 ms, enqueue 6.3897 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.573 ms - Host latency: 24.707 ms (end to end 24.7175 ms, enqueue 6.37815 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.552 ms - Host latency: 24.6826 ms (end to end 24.6932 ms, enqueue 6.35994 ms)
[11/16/2020-13:15:32] [I] Average on 10 runs - GPU latency: 24.4029 ms - Host latency: 24.5328 ms (end to end 24.5435 ms, enqueue 10.0791 ms)
[11/16/2020-13:15:32] [I] Host Latency
[11/16/2020-13:15:32] [I] min: 24.4467 ms (end to end 24.4572 ms)
[11/16/2020-13:15:32] [I] max: 34.8445 ms (end to end 34.8571 ms)
[11/16/2020-13:15:32] [I] mean: 24.9597 ms (end to end 24.9704 ms)
[11/16/2020-13:15:32] [I] median: 24.5864 ms (end to end 24.5973 ms)
[11/16/2020-13:15:32] [I] percentile: 34.8171 ms at 99% (end to end 34.8304 ms at 99%)
[11/16/2020-13:15:32] [I] throughput: 40.0464 qps
[11/16/2020-13:15:32] [I] walltime: 3.07144 s
[11/16/2020-13:15:32] [I] Enqueue Time
[11/16/2020-13:15:32] [I] min: 4.98193 ms
[11/16/2020-13:15:32] [I] max: 13.2275 ms
[11/16/2020-13:15:32] [I] median: 7.02148 ms
[11/16/2020-13:15:32] [I] GPU Compute
[11/16/2020-13:15:32] [I] min: 24.3189 ms
[11/16/2020-13:15:32] [I] max: 34.6916 ms
[11/16/2020-13:15:32] [I] mean: 24.8289 ms
[11/16/2020-13:15:32] [I] median: 24.4583 ms
[11/16/2020-13:15:32] [I] percentile: 34.6632 ms at 99%
[11/16/2020-13:15:32] [I] total compute time: 3.05395 s
&&&& PASSED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/home/jetson/detect/mb2-ssd-lite.onnx --verbose
How to solve this kind of error as I searched and haven't find any solution yet.
