I am trying to convert my tensorflow model into an tensorRT model in order to use it with nvinfer of deepstream.
Unfortunately I always get the following error in the building step:
2021-08-04 13:12:25.059598: W tensorflow/core/framework/op_kernel.cc:1767] OP_REQUIRES failed at transpose_op.cc:157 : Invalid argument: transpose expects a vector of size 4. But input(1) is a vector of size 5
2021-08-04 13:12:25.060068: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:588] Running native segment forStatefulPartitionedCall/sequential/conv_lst_m2d/TRTEngineOp_0_0 due to failure in verifying input shapes: Input shapes do not match input partial shapes stored in graph, for StatefulPartitionedCall/sequential/conv_lst_m2d/TRTEngineOp_0_0: [[16,128,128,1]] != [[?,16,1,128,128]]
2021-08-04 13:12:25.060151: W tensorflow/core/framework/op_kernel.cc:1767] OP_REQUIRES failed at trt_engine_op.cc:401 : Cancelled: Function was cancelled before it was started
File "savedmodel_to_trt.py", line 25, in <module>
converter.build(input_fn=my_input_fn)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/compiler/tensorrt/trt_convert.py", line 1174, in build
func(*map(ops.convert_to_tensor, inp))
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py", line 1655, in __call__
return self._call_impl(args, kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/wrap_function.py", line 247, in _call_impl
args, kwargs, cancellation_manager)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py", line 1673, in _call_impl
return self._call_with_flat_signature(args, kwargs, cancellation_manager)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py", line 1722, in _call_with_flat_signature
return self._call_flat(args, self.captured_inputs, cancellation_manager)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py", line 1924, in _call_flat
ctx, args, cancellation_manager=cancellation_manager))
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/function.py", line 550, in call
ctx=ctx)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/eager/execute.py", line 60, in quick_execute
inputs, attrs, num_outputs)
tensorflow.python.framework.errors_impl.InvalidArgumentError: transpose expects a vector of size 4. But input(1) is a vector of size 5
[[node StatefulPartitionedCall/sequential/conv_lst_m2d/transpose_2 (defined at savedmodel_to_trt.py:18) ]] [Op:__inference_pruned_38898]
Function call stack:
pruned
And this is the code I am using to convert it:
import tensorflow as tf
from tensorflow.python.compiler.tensorrt import trt_convert as trt
import numpy as np
input_saved_model_dir="savedmodel/"
output_saved_model_dir="trtmodel/"
conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS
conversion_params = conversion_params._replace(
max_workspace_size_bytes=(1<<32))
conversion_params = conversion_params._replace(precision_mode="FP16")
maximum_cached_engines=100)
converter = trt.TrtGraphConverterV2(
input_saved_model_dir=input_saved_model_dir,
conversion_params=conversion_params)
converter.convert()
def my_input_fn():
inp1 = np.random.normal(size=(16, 128, 128,1)).astype(np.float32)
yield [inp1]
converter.save(output_saved_model_dir)
Any tips on what I am doing wrong?
