IP cameras and AGX Xavier
Hello!
How can i connect my IP cameras to AGX Xavier?
I need to use some expansion module(Microchip PD-IM-7618T4, Cincoze CMI-M12PoE114/UB0710)?
Have a check with vendor what kind of interface for this IP camera connect to host?
Xavier have USB or MIPI interface for camera.
I’m going to use 8 IP cameras with Gigabit PoE
I have successfully connected a IP camera that outputs RTSP-stream. You can configure a gstreamer pipeline for that quite easily, a lot of examples are floating around.
https://gstreamer.freedesktop.org/documentation/additional/rtp.html?gi-language=c
In case your IP camera does not support RTSP you need other vendor dependant solution.
