So I’m going to connect x8 IP cameras to AGX Xavier and I’ll need a lot of RJ45 connectors.
Can I implement it on PCIe x16 connector?
If I use this devise LRES2008PT-PoE (Professional network card solution & intelligent hardware platform solution provider|LR-LINK Lianrui) will it work?
And for example, if I need more PCIe slots, can i use some kind of adapter to create x2-x3 PCIe connectors?
For Xavier, it is general PCIe port for usage from hardware side. The device you mentioned is not validated on Jetson Xavier dev kit, you can try that, the main workload is tuning in sw.
