Is 8GB VRAM Enough for Basic Isaac Sim 5.1 Usage?
For Isaac Sim 5.1, the minimum requirement is listed as an RTX 4080 with 16 GB of VRAM. My laptop has an RTX 5060 with 8 GB of VRAM. Would it still be able to handle basic tasks, such as building simple 3D scenes and testing code? For actual model training, I plan to rent a cloud GPU.
Hi @lethanhtaicute345 — short answer: it’ll launch and let you learn the UI, build simple scenes, and test code, but expect to hit VRAM limits quickly. The RTX renderer alone needs up to ~7 GB, so on 8 GB you have very little headroom.
For your plan (learn/prototype locally, train in the cloud) it’s workable if you keep scenes minimal. A couple of flags help:
./isaac-sim.sh --/app/content/emptyStageOnStart=true
and close other GPU apps. Treat it as a learning/dev box, not a place to run full workcells. The 16 GB minimum is real once scenes get realistic.
