Is it possible to customize the IGX Orin?
I’m interested in getting access to the SafeMCU that the IGX Orin makes available. We don’t need the RTX6000 and would save a lot of cost if we could have a GPU spec similar to the AGX Orin. Basically wondering if we can swap out certain components to make the cost make sense for us.
The IGX Devkit comes with an IGPU: NVIDIA Ampere with 2.048 Cores and 64 Tensor-Cores, with 248 TOPS.
The discrete GPU is always optional.
If this performance is sufficient you do not need to add a dGPU.
When adding a dGPU currently only the A6000, and 6000Ada are supported.
