I have a Jetson AGX Xavier with JP4.6 that I cannot upgrade further as I have incompatible with JP5 camera drivers. I would like to run Triton on that Jetson as a local server and I want to use DALI+TRT ensambles.
I am however facing the following problem. DALI has become available by default in Triton since version 20.11 which is more than 2 years ago, however according to the official Triton release notes, it requires CUDA 11.1
And JetPack 4.6 comes with CUDA 10.2.
I tried to run a docker image on the Jetson of a more up-to-date triton container, 22.10, and added a simple Dali model to serve as a test and I get the following error:
File "<string>", line 5, in <module>
File "<frozen importlib._bootstrap>", line 553, in module_from_spec
AttributeError: 'NoneType' object has no attribute 'loader'
File "<string>", line 8, in <module>
File "/opt/tritonserver/backends/dali/conda/envs/dalienv/lib/python3.8/site-packages/nvidia/dali/_utils/autoserialize.py", line 70, in invoke_autoserialize
dali_pipeline().serialize(filename=filename)
File "/opt/tritonserver/backends/dali/conda/envs/dalienv/lib/python3.8/site-packages/nvidia/dali/pipeline.py", line 1166, in serialize
self._init_pipeline_backend()
File "/opt/tritonserver/backends/dali/conda/envs/dalienv/lib/python3.8/site-packages/nvidia/dali/pipeline.py", line 693, in _init_pipeline_backend
self._pipe = b.Pipeline(self._max_batch_size,
RuntimeError: CUDA runtime API error cudaErrorInsufficientDriver (35):
CUDA driver version is insufficient for CUDA runtime version
So my question is, has anyone done this before? Can I run DALI backed triton server on JP4.6? I’d love to hear your feedback before I waste a dozen hours over something that could be bound to fail.
