Hi, i have jetson xavier agx 16gb. I have flashed my device (JP 5.1.4, latest as of today).
When i looked support matrix(matrix) for xavier agx latest supported Triton version is
Release 2.36.0 corresponding to NGC container 23.07
I have updated my cuda version to latest supported cuda 12.2 successfully.
but when i run docker compose with
image: nvcr.io/nvidia/tritonserver:23.07-py3
i get
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'csv'
invoking the NVIDIA Container Runtime Hook directly (e.g. specifying the docker --gpus flag) is not supported. Please use the NVIDIA Container Runtime instead.: unknown
i was failing all the time using desktop version dockers. I used dusty jetson containers version 35.4.1
now it is working but will upgrading cuda make any benefit to me i was wondering. Also thanks for your reply.
