Is possible to plug QSFP28 (100G) Direct Cable in First port of Connext5-EN Dual Ports (100G) and QSFP (40G) Direct Cable in Second port of same NIC?
For example :
MCP1600-C002 in first port
MCP1700-B002E in second port
Hello Jean-Philippe,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Yes, you can insert a 100GbE cable in one port and a 40GbE cable in the other port. Both ports function independently from each other. Just make sure the cables you are using are in the validated/tested list of cables mentioned in the RN of the f/w of the adapter → https://docs.mellanox.com/display/ConnectX5Firmwarev16292002/Firmware+Compatible+Products
Thank you and regards,
~NVIDIA Networking Technical Support
Hello Martijn
Thank you for this answer
Regards
Jean-Philippe
