Hello
Is the following 100gbe crossover cable ? I mean if the TX of one side wired to the RX of the other side ?
https://www.mellanox.com/related-docs/prod_cables/PB_MCP1600-Cxxx_100GbE_QSFP28_DAC.pdf
Shal
Hello
Shal
QSFP28 DAC copper cables, like the one you linked, have no dedicated TX and RX pins unlike 100baseT RJ45. It is similar to how 10Gb Ethernet over CAT6A works in that the interfaces negotiate to figure out which pins to use for what.
Hi Woelkers
And can you refer me to a relevant documentation on the subject ?
Is there any detailed spec about this cable ?
Regards
Shalom
