Need some more understanding about your statement “theoretically it can work with inbox driver” also, which driver are you referring to as the inbox driver?
Further, I would like to explain my purpose, for which I am seeking the details :-
I have a Client(Host) setup with Centos 7.2, kernel 4.13.10 and Mellanox Connectx-3 RNIC.
I do not install MLNX_OFED because when I install MOFED, I am not allowed to insert my ‘nvme-rdma’ module.
Hence I load the default driver with my modifications (nvme-core, nvme, nvme-fabrics, nvme-rdma).
I would like to know if there a way I can use IBdump to capture the communication with my setup.
Also is there any other way I can capture the RDMA traffic while using the default drivers or OFA OFED?
The Ibdump is a tool that comes with MLNX_OFED and tested on top of MLNX_OFED, theoretically it can work with inbox driver.
The firmware should be compatible with MLNX_OFED version , you can check the release notes of each OFED version under the supported firmware versions section .
“theoretically it can work with inbox driver” , means it wasn’t tested and certified by Mellanox , We cannot guarantee full functionality of the tool on untested driver.
