Is the e-con See3CAMCU50 supported on TX2?
Hi am2266,
As mentioned in the section titled ‘USB 3.0 webcams known to be working’ in the page Jetson/Cameras - eLinux.org , See3CAMCU50 has been tested and found to be working with TK1. We will test it on TX2 and update the above mentioned table, shortly. Will also post the results here.
Hi am2266,
We tested See3CAM_CU50 with GStreamer v1.0, on TX2 and found this working fine. Let us know whether you need any more info. in this regard.
and is it possible to achieve 30fps at 1080p with MJPEG and usb 3?
Yes am2266, in TX2 + See3CAM_CU50, on USB 3.0, 1080p 30fps works fine. This specific test case had indeed been tested successfully with GStreamer v1.0.
Hope this helps.
