Any good 720p 120fps camera for the TX2 ?
Hello there,
I am currently searching for a Jetson TX2 compatible USB camera that could have the following specifications:
  • 720p at 120fps (some cameras I’ve seen have a USB 2.0 port, but is that really enough to transmit 120 images per second? Is USB 3.0 not needed for that?);
  • No distortion (i.e. no fisheye or anything. FOV doesn’t need to be wide anyway);
  • Could go up to 8MP (that would be nice);
Thanks in advance for your answers!
I would suggestion to use USB3.0 to avoid the bandwidth problem cause the performance issue.
