4 USB3.0 Cameras
I was wondering if anyone knows if the TX1 can handle four usb3.0 cameras at a time? The resolution would be 808x608 at 50 FPS.
Thank you for the help!
Hi Swooshftw
The usb 3.0 speed is up to 5000 Mbps and it should be support your use case in theory.
Hi ShaneCCC,
Okay thanks! I am going to go ahead and try it out and will post back on this thread with my results.
I have not had luck opening several USB3 cameras on a TX1. See my post: [url]https://devtalk.nvidia.com/default/topic/936302/support-for-multiple-high-resolution-usb-3-0-cameras-/#4880333[/url]
The theoretical speed limit of usb3 is 5Gbps but the practical limit is more like half that.
Let me know if you get it working! Good luck!
