Is there a limit on the number of streams in deepstream 8.0?
• Hardware Platform: GPU(RTX5090)
• DeepStream Version: 8.0
• TensorRT Version: 10.9.0.34
• NVIDIA GPU Driver Version: 575.64
• Issue Type: questions
• CUDA version: 12.8
• When running more than 27 streams on a pipeline, the frame rate printed by nvdsosd is less than the original video’s 25 fps, only around 16 fps, at which point the decoder utilization is only 50%. However, when I reduced the number of streams to 18, the frame rate was able to reach 25 fps.
What is the GPU utilization when you run your app with 27 streams?
About 40%
Can you tell us your complete pipeline and configurations?
This pipeline diagram,Because the test removes the subsequent components of the nvstreamdemux:
pipeline.zip (468.7 KB)
Configuration file:
ds_app_config.zip (645 Bytes)
config_infer_primary_yolo11_all.txt (927 Bytes)
Can you set the “sync-inputs” property of nvstreammux to “FALSE”?
What are the resolution and codec format of your rtsp streams?
We have tested turning off sync, but the situation is still the same
3840x2160,h265
If your rtsp streams are all the same, the 27 4k@25fps HEVC streams decoding may exceed the hardware limitation of RTX 5090.
However, the decoder usage is only about 50%. Does this limit refer to quantity? Is there any official explanation from 5090?
How did you measure the decoder usage?
Use the terminal command nvidia-smi dmon
Currently no specific codec performance data for RTX 5090. It has two 6th generation decoder cores. GeForce RTX 5090 Graphics Cards | NVIDIA
The 4th & 5th generation decoder core performance data is available in Video Codec SDK | NVIDIA Developer.
You can also test the decoding only case to verify the decoder performance.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
