Is there a Python way to get and / or set the USD Root Layer path for a scene?
I notice this value is different for every project.
Thanks, I need this to create a Physics Scene automatically. The commands Window shows the value of the current project, but to reuse the code I need the current scene’s value.
try this?
from pxr import Usd
layer = stage.GetRootLayer()
it’s different each time because the file was never saved. so they become ‘temp’ files, or ‘anon’ in memory each time you do file > new, i think. once saved, the layer path will become the path of the USD file.
Thank you, I will try it shortly.
That worked! And you are correct, once saved the Root Layer path becomes the path to the USD project.
Many thanks.
