I am trying to make essentially my own custom designed smartphone with a Jetson nano as it’s core. And the dev board isn’t in the right form factor I need, it also has ports I’m not going to use, so I want to make a custom PCB. Also can the pcie bus be used to add more then one m.2 slot? I need wireless, cellular, and an nvme drive if possible. I’m very new to all of this so even if you could just point me in the direction to dive into I’d appreciate it!
Yes, you can download the design files from here: Jetson Download Center | NVIDIA Developer
Schematic, as well as layout files, are also available.
I am also developing the PCB for machine vision, for wifi and Bluetooth you can use the. intel module.
If you need any help you can contact me here: Ruchapatel2711@gmail.com
