The A2F plugin in blender works well when import blendshape animation from json file.But it can’t import joints animation.So I wrote my own script to import the joints animation.The script now can successfully read the joints animation, but the joint rotations got wrong orientation.
Here is my code:
import bpy
import json
import mathutils
bpy.ops.wm.console_toggle()
def ReadJsonFile(file_path):
try:
with open(file_path, 'r') as json_file:
data = json.load(json_file)
return data
except FileNotFoundError:
print(f"File '{file_path}' not found.")
return None
jsonData = ReadJsonFile(r'G:\Omniverse\Audio2FaceTest\Export\ToBlender\a2f_export_face_bsweight.json')
print(jsonData["trackPath"])
joints = jsonData["joints"]
rotations = jsonData["rotations"]
numFrames = jsonData["numFrames"]
rootBone = bpy.data.objects["Root"]
for i in range(len(joints)):
curBone = rootBone.pose.bones.get(joints[i].split("/")[-1])
curBone.rotation_mode = 'QUATERNION'
print(curBone)
for fr in range(numFrames):
quaternion = mathutils.Quaternion((rotations[fr][i][0], rotations[fr][i][1], rotations[fr][i][2], rotations[fr][i][3]))
curBone.rotation_quaternion = quaternion
curBone.keyframe_insert("rotation_quaternion", frame = fr)
