I’m creating some micro-benchmarks in which I’d like to disable the Carmel’s data prefetcher programatically to see how the Xavier behaves without it.
Revising the documentation of another very well known ARM v8 architecture (Cortex A-53), I found the control register CPUACTLR_EL1, which provides a way to enable/disable this feature in the Cortex core (see L1PCTL). This makes possible to enable/disable the prefetcher programatically by simply adding this snippet before executing your benchmark [0]:
#define mask_DPreFetch 0xA000
void DisablePrefetcher()
unsigned long long r = 0;
unsigned long long mask = ~mask_DPreFetch;
__asm__ __volatile__ (
"MRS %0, S3_1_C15_C2_0" : "=r" (r)
r &= mask;
"MSR S3_1_C15_C2_0, %0" : : "r" (r)
I was wondering if there is something similar in the XAVIER, because when I tried to execute these same instructions in Carmel I get Illegal instruction (core dumped)
, which makes total sense, since the architecture is not totally equivalent besides being an ARM V8 brother.
Thank you for the help in advance!
