I’m following the Isaac ROS FoundationPose tutorial as described in this guide.
Steps 1-3 worked well:
Step 1: Isaac ROS ESS tutorial - Completed
Step 2: Isaac ROS RT-DETR tutorial - Completed
Step 3: Isaac ROS FoundationPose Quickstart Guide - Completed
However, when I launched the final script:
ros2 launch isaac_ros_foundationpose isaac_ros_foundationpose_isaac_sim.launch.py
I found that the disparity and depth images were not published correctly.
The /disparity
topic contains repetitive values like:
header:
stamp:
sec: 28
nanosec: 716668164
frame_id: sim_camera
image:
height: 576
width: 960
encoding: 32FC1
data:
- 0
- 0
- 128
- 191
f: 478.90576171875
min_disparity: 0.0
max_disparity: 2147483648.0
delta_d: 0.0
Disparity values appear invalid (repeating 0s and unrealistic numbers).
max_disparity
is set to 2147483648.0, which seems incorrect.
delta_d
is 0.0, meaning no disparity steps were calculated.
The ESS node is running, but the disparity output seems wrong.
Possible Cause?
My scene in Isaac Sim has a white ground plane.
I suspect that the lack of texture on these surfaces is causing stereo disparity matching to fail.
The scene is as below,
And this is when I ran the ESS node,
I ran the above ESS node with threshold = 0.35
- Other nodes (
RT-DETR
, etc.) seem to be running correctly. - The only issue I could find is in the
/disparity
and/depth
topics, where the values look incorrect. - I suspect that incorrect depth estimation is causing FoundationPose to fail because FoundationPose depends on accurate depth input.
- Could the white surfaces (low-texture issue) be the reason for disparity failure?
- What is the best way to improve disparity estimation in this setup?
+, as I published 4 topics in Isaac sim
/front_stereo_camera/left/camera_info,
/front_stereo_camera/left/image_rect_color,
/front_stereo_camera/right/camera_info,
/front_stereo_camera/right/imgae_rect_color.
- Can I publish depth data from Isaac Sim and feed it directly into FoundationPose after resizing?
- Would this be the best solution to avoid stereo matching issues?
