I’m trying to install the ISAAC ROS system, but I’m getting the following errors from Docker:
cmd used to run:
cd ${ISAAC_ROS_WS}/src/isaac_ros_common && \
./scripts/run_dev.sh
System:
Ubuntu 22.04LTS
ROS2 Humble
Isaac Sim V2023.1.1
#RUN --mount=type=cache,target=/var/cache/apt \
243
# mkdir -p ${ROS_ROOT}/src && cd ${ROS_ROOT}/src \
244
# && git clone https://github.com/ros-planning/moveit_task_constructor.git -b humble \
245
# && cd moveit_task_constructor && source ${ROS_ROOT}/setup.bash \
246
# && cd msgs && bloom-generate rosdebian && fakeroot debian/rules binary \
247
# && cd ../ && apt-get install -y ./*.deb && rm ./*.deb \
248
# && cd rviz_marker_tools && bloom-generate rosdebian && fakeroot debian/rules binary \
249
250
# && cd core && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
251
252
# && cd capabilities && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
253
254
# && cd visualization && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
255
256
# && cd demo && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
257
The above lines are causing the error, and the docker error log is given in the below text file
docker error log.txt (103.3 KB)
I’ve tried to divide the RUN command to multiple smaller RUN commands and the moveit_task_constructor/core is the one posing the error.
How do i fix this??
Refernces used:
ISAAC ROS MISSION CLIENT: link
I’ve managed to fix the errors:
The error’s are
- The error log shows that the .deb packages are not being generated in the expected directory.
- The error indicates that py_binding_tools is missing, which is a dependency required by the moveit_task_constructor.
Update the following lines from 241
Original Lines
# Install MoveIt task constructor from source. The "demo" package depends on moveit_resources_panda_moveit_config,
# installed from source above.
Updated Lines
# Install necessary tools
RUN apt-get update && apt-get install -y \
git \
fakeroot \
python3-bloom \
ros-humble-py-binding-tools \
&& rm -rf /var/lib/apt/lists/*
# Create a cache mount and clone the repository
mkdir -p ${ROS_ROOT}/src && \
cd ${ROS_ROOT}/src && \
|| { echo "Git clone failed"; exit 1; }
# Source setup.bash and build msgs
/bin/bash -c ' \
echo "Sourcing setup.bash" && \
source ${ROS_ROOT}/setup.bash && \
cd ${ROS_ROOT}/src/moveit_task_constructor/msgs && \
echo "Generating rosdebian for msgs" && \
bloom-generate rosdebian && \
echo "Building msgs package" && \
fakeroot debian/rules binary && \
echo "Checking for generated .deb or .ddeb files" && \
find .. -name "*.deb" -o -name "*.ddeb" && \
if find .. -name "*.deb" -o -name "*.ddeb" 1> /dev/null 2>&1; then \
echo "Installing msgs package" && \
apt-get install -y $(find .. -name "*.deb" -o -name "*.ddeb") && \
echo "Cleaning up msgs package" && \
find .. -name "*.deb" -o -name "*.ddeb" -delete; \
else \
echo "No .deb or .ddeb files found, build failed"; \
exit 1; \
fi \
|| { echo "Building msgs failed"; exit 1; }'
# Continue with the other packages similarly
# Build rviz_marker_tools
/bin/bash -c ' \
cd ${ROS_ROOT}/src/moveit_task_constructor/rviz_marker_tools && \
echo "Generating rosdebian for rviz_marker_tools" && \
echo "Building rviz_marker_tools package" && \
echo "Installing rviz_marker_tools package" && \
echo "Cleaning up rviz_marker_tools package" && \
else \
exit 1; \
fi \
|| { echo "Building rviz_marker_tools failed"; exit 1; }'
# Repeat similar steps for core, capabilities, visualization, and demo
# Build core
/bin/bash -c ' \
cd ${ROS_ROOT}/src/moveit_task_constructor/core && \
echo "Generating rosdebian for core" && \
echo "Building core package" && \
fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck && \
echo "Installing core package" && \
echo "Cleaning up core package" && \
else \
exit 1; \
fi \
|| { echo "Building core failed"; exit 1; }'
# Build capabilities
/bin/bash -c ' \
cd ${ROS_ROOT}/src/moveit_task_constructor/capabilities && \
echo "Generating rosdebian for capabilities" && \
echo "Building capabilities package" && \
echo "Installing capabilities package" && \
echo "Cleaning up capabilities package" && \
else \
exit 1; \
fi \
|| { echo "Building capabilities failed"; exit 1; }'
# Build visualization
/bin/bash -c ' \
cd ${ROS_ROOT}/src/moveit_task_constructor/visualization && \
echo "Generating rosdebian for visualization" && \
echo "Building visualization package" && \
echo "Installing visualization package" && \
echo "Cleaning up visualization package" && \
else \
exit 1; \
fi \
|| { echo "Building visualization failed"; exit 1; }'
# Build demo
/bin/bash -c ' \
cd ${ROS_ROOT}/src/moveit_task_constructor/demo && \
echo "Generating rosdebian for demo" && \
echo "Building demo package" && \
echo "Installing demo package" && \
echo "Cleaning up demo package" && \
else \
exit 1; \
fi \
|| { echo "Building demo failed"; exit 1; }'
You could also face docker runtime not converted to nvidia runtime. If not automatically done, edit the daemon.json file as follows:
sudo nano /etc/docker/daemon.json
edit it as follows:
"runtimes": {
"nvidia": {
"path": "nvidia-container-runtime",
"runtimeArgs": []
"default-runtime": "nvidia"
and restart docker
