We are working on a Jetson Orin Nano (8 GB) and are building an image segmentation pipeline using the following Isaac ROS packages:
isaac_ros_dnn_image_encoder — to preprocess raw camera images
isaac_ros_tensor_rt — for GPU inference
isaac_ros_unet — to generate the final segmentation mask
The camera stream is 640×512, 15–30 FPS, BGR8.
Problem Description
The pipeline does not behave deterministically:
Sometimes it starts and runs correctly
Sometimes it fails to start properly
The failure is intermittent, even when no launch configuration is changed.
Observed Behavior
During the failure cases, we repeatedly see messages such as:
10.0s passed while waiting to push a message entity (eid=XXX) to the receiver cam_info_in
This happens even though the camera /image_raw and /camera_info topics are synchronized and publishing normally.
Logs and Launch File
Here are the logs with DEBUG level enabled:
isaac_logs.log (2.2 MB)
Here is the launch file defining the pipeline:
isaac_ros_unet_tensor_rt.launch.txt (21.2 KB)
I tried to add a delay for the encoder runtime, but it did not solve the issue.
Software Environment
Some additional info:
- JetPack 6.0 (Jetson Linux 36.3)
- Isaac ROS v3.1 (base container from official installation guide)
- ROS 2 Humble
The nodes are running inside a single component_container_mt as recommended for performance.
Hypothesis
Since the issue is intermittent and sensitive to timing, it looks like the GXF / NITROS graph may not always initialize the internal components (e.g., image encoder ports) in a deterministic manner, and running two separate containers did not solve the issue.
Could you please confirm:
Whether this is a known issue in Isaac ROS 3.1 / JetPack 6.0
Whether there is a recommended workaround (e.g., splitting nodes into multiple containers, adding startup synchronization, adjusting NITROS configuration, etc.)
Whether this behavior is expected if camera_info arrives slightly later than image frames
Whether additional GXF debug flags can help trace the graph initialization order
Any guidance on achieving a deterministic startup for this pipeline would be greatly appreciated.
Thank you in advance!
Best regards,
Simone
