"Isaac Sim 4.5" has many issues with "Non-Visual Materials".The documentation also contains errors
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
I’m very sorry, but I’ve encountered a series of issues while using Isaac Sim 4.5.
I wanted to use “Non-Visual Materials” to create some “point cloud noise”, so I followed the documentation and ran some tests, but I discovered many problems.
I launched Isaac Sim 4.5 according to the documentation in order to use “Non-Visual Materials”. The startup method was as follows:
./isaac-sim.sh \
--/rtx/materialDb/nonVisualMaterialCSV/enabled=false \
--/app/rtxSensorSample/contentMaterialTest/enabled=true \
--/rtx/rtxsensor/coordinateFrameQuaternion="0.5,-0.5,-0.5,-0.5"
First, the examples in the documentation don’t match what’s actually in Isaac Sim 4.5.
I located the sample case by following the specified path, but encountered some issues upon opening it.
When I switched to the “RTXSensorSample” camera, I found it was completely different from what the documentation described.
The green materials were just ordinary materials, not as expected.According to the documentation, there should be “custom string inputs: nonvisual:attributes=‘emissive’” configurations for these “Non-Visual Materials.” However, in reality, they are just standard PBR materials. As a result, even after switching cameras, they produce no effect.
Later, I created a new scene to conduct further testing. The green section was assigned a “Non-Visual Material” by adding it via “Add” + “Attribute,” with the material named “b.” All other materials remained standard PBR materials labeled “a.”
Next, I added an “RTXSensor” to the scene.Since I noticed some configuration requirements, I restarted Isaac Sim and set up the necessary parameters before creating the “RTX sensor” in Python.
Here’s my complete code implementation:
import carb
carb.settings.get_settings().set_bool("/rtx/materialDb/nonVisualMaterialCSV/enabled", False)
import omni.kit.commands
from pxr import Gf
lidar_config = "Example_Rotary"
# 1. Create The Camera
_, sensor = omni.kit.commands.execute(
    "IsaacSensorCreateRtxLidar",
    path="/sensor",
    parent=None,
    config=lidar_config,
    translation=(-5.83932, 0, 1.0),
    orientation=Gf.Quatd(1,0,0,0),
# 2. Create and Attach a render product to the camera
render_product = rep.create.render_product(sensor.GetPath(), [1, 1])
# 3. Create Annotator to read the data from with annotator.get_data()
annotator = rep.AnnotatorRegistry.get_annotator("RtxSensorCpuIsaacCreateRTXLidarScanBuffer")
annotator.attach(render_product)
# 4. Create a Replicator Writer that "writes" points into the scene for debug viewing
writer = rep.writers.get("RtxLidarDebugDrawPointCloudBuffer")
writer.attach(render_product)
However, the results were disappointing - it appears to have no effect at all. My intended outcome was for the laser to generate some noise when hitting the mirror, but currently there’s no observable effect.
I’m unsure where the issue lies. It seems the “Non-Visual Materials” aren’t functioning as expected to achieve the desired simulation behavior.
I’d really appreciate some guidance on this issue.
Collected_111.zip (3.8 KB)
Has this issue been resolved? I am unable to reproduce this problem. My observations are consistent with the documentation.
@VickNV I am very sorry, I have tried multiple times and the result is still the same mistake as before.
Hello, any solutions to this? I am using Issac Sim 5.1.0 and still not able to simulate “point cloud noise” even after setting the Non-visual materials correctly.
@adiljus2
I’ve been following up on this issue, but I still haven’t managed to retrieve any point cloud data.
Regarding the “RTX Sensor,” how did you create it and obtain the data?
@VickNV @adiljus2
I made the same attempt in Isaac Sim 5.10, setting up “Non-Visual Materials,” but still couldn’t obtain the noise for the point cloud.
Hi @Julie_A, @adiljus2,
This issue has been addressed in Isaac Sim 6.0, which includes a complete end-to-end example for RTX LiDAR with non-visual materials:
  standalone_examples/api/isaacsim.sensors.rtx/apply_nonvisual_materials.py
The example covers:
  • Applying non-visual materials to scene objects
  • Creating an RTX LiDAR sensor
  • Reading intensity values via the GenericModelOutput annotator
For more details, see the resolution in the related thread: Issue with Isaac 5.10 “Non-Visual Materials” Feature
Please upgrade to Isaac Sim 6.0 and try the new example. If you still encounter issues, open a GitHub issue at isaac-sim/IsaacSim with a minimal repro script.
Closing this thread as resolved.
