Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA GeForce RTX 4090
- Driver Version: 580.126.09
Topic Description
Isaac Sim 6.0.0 WebRTC livestream fails with `StreamSdkException 800b0000` on a headless RTX 4090 Docker server
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
## Environment
Server:
```text
OS: Ubuntu 22.04.5 LTS
Kernel: 5.15.0-177-generic
Docker: 29.4.3
NVIDIA driver: 580.126.09
CUDA version reported by nvidia-smi: 13.0
GPU: 8x NVIDIA GeForce RTX 4090
Target GPU: GPU 1, PCI bus id 00000000:0C:00.0
Docker image:
```text
NVIDIA NGC Isaac Sim Docker image, tag `6.0.0`
Client:
```text
macOS
Isaac Sim WebRTC Streaming Client 2.0.0
Network:
```text
Server public IP: SERVER_PUBLIC_IP
Default WebRTC signal port: 49100/tcp
Default WebRTC stream port: 47998/udp
Docker network mode: host
GPU/display status on the server:
```text
index, name, driver_version, pci.bus_id, display_active, display_mode, memory.used [MiB]
0, NVIDIA GeForce RTX 4090, 580.126.09, 00000000:08:00.0, Disabled, [Requested functionality has been deprecated], 18254 MiB
1, NVIDIA GeForce RTX 4090, 580.126.09, 00000000:0C:00.0, Disabled, [Requested functionality has been deprecated], 6 MiB
2, NVIDIA GeForce RTX 4090, 580.126.09, 00000000:89:00.0, Disabled, [Requested functionality has been deprecated], 5 MiB
3, NVIDIA GeForce RTX 4090, 580.126.09, 00000000:8A:00.0, Disabled, [Requested functionality has been deprecated], 5 MiB
4, NVIDIA GeForce RTX 4090, 580.126.09, 00000001:08:00.0, Disabled, [Requested functionality has been deprecated], 43468 MiB
5, NVIDIA GeForce RTX 4090, 580.126.09, 00000001:0C:00.0, Disabled, [Requested functionality has been deprecated], 43468 MiB
6, NVIDIA GeForce RTX 4090, 580.126.09, 00000001:8C:00.0, Disabled, [Requested functionality has been deprecated], 43468 MiB
7, NVIDIA GeForce RTX 4090, 580.126.09, 00000001:8D:00.0, Disabled, [Requested functionality has been deprecated], 43468 MiB
`nvidia-xconfig --query-gpu-info` reports `Number of Display Devices: 0` for all GPUs.
## Docker Command
The container is started with host networking and explicit GPU capabilities:
```bash
docker run -it \
–name isaac-sim-60-stream-debug \
--gpus ‘“device=1”,“capabilities=compute,utility,graphics,video,display”’ \
–entrypoint bash \
--network host \
–shm-size=8g \
--ulimit memlock=-1 \
–ulimit stack=67108864 \
-e ACCEPT_EULA=Y \
-e OMNI_ENV_PRIVACY_CONSENT=Y \
-e NVIDIA_DRIVER_CAPABILITIES=all \
-e ISAAC_PUBLIC_ENDPOINT=SERVER_PUBLIC_IP \
-v /host/isaac:/workspace/isaac:rw \
-v /host/isaac-cache/.cache:/isaac-sim/.cache:rw \
-v /host/isaac-cache/nvidia-omniverse:/isaac-sim/.nvidia-omniverse:rw \
-v /host/project:/workspace/project:rw \
NGC_ISAAC_SIM_6_IMAGE
I also tested exposing `/dev/nvidia-caps` explicitly:
```bash
--device /dev/nvidia-caps/nvidia-cap1
--device /dev/nvidia-caps/nvidia-cap2
Inside the container, `/dev/nvidia-caps/nvidia-cap1` and `/dev/nvidia-caps/nvidia-cap2` are visible, but the WebRTC failure remains the same.
## Reproduction Steps
Inside the Isaac Sim 6.0.0 container, start the official headless streaming app:
```bash
/isaac-sim/runheadless.sh -v \
–/exts/omni DOT kit DOT livestream DOT app/primaryStream/publicIp=SERVER_PUBLIC_IP
Then connect from macOS Isaac Sim WebRTC Streaming Client:
```text
Server: SERVER_PUBLIC_IP
Signal: 49100
Stream: 47998
I also tried explicit ports, WebRTC stream type, lower FPS, and lower resolution:
```bash
–/exts/omni DOT kit DOT livestream DOT app/primaryStream/publicIp=SERVER_PUBLIC_IP \
--/exts/omni DOT kit DOT livestream DOT app/primaryStream/signalPort=49100 \
–/exts/omni DOT kit DOT livestream DOT app/primaryStream/streamPort=47998 \
--/exts/omni DOT kit DOT livestream DOT app/primaryStream/streamType=webrtc \
–/exts/omni DOT kit DOT livestream DOT app/primaryStream/targetFps=15 \
--/app/window/width=640 \
–/app/window/height=360
The result is the same.
## Actual Result
The Mac WebRTC client opens a black window. Isaac Sim logs show that the signal path reaches the server, but video stream creation fails:
```text
Display Mode : Requested functionality has been deprecated
Display Attached : No
Display Active : Disabled
Started primary stream server on signal port 49100 and stream port 47998
Isaac Sim Full Streaming App is loaded.
Processing 11 signaling headers
[Fatal] [omni DOT kit DOT livestream DOT streamsdk] [NvscStreamingSess] Failed to setup the streaming session because:
StreamSdkException 800b0000 [NVST_R_GENERIC_ERROR] Failed to create video stream 0
## Expected Result
The macOS Isaac Sim WebRTC Streaming Client should display the Isaac Sim viewport.
## Network Checks
TCP signal port is reachable from the Mac:
```bash
nc -vz SERVER_PUBLIC_IP 49100
UDP packets from the Mac reach the Linux server:
```bash
sudo timeout 20 tcpdump -ni any udp port 47998
Example captured traffic:
```text
eth0 In IP CLIENT_PUBLIC_IP:ephemeral-port > SERVER_PRIVATE_IP:47998 UDP, length 5
Since Isaac logs `Processing 11 signaling headers`, the client is also reaching the Isaac Sim signaling server.
## What I Have Already Tried
### 1. Offline rendering works
Using Isaac Sim 6.0.0 Docker, I can render images headlessly from a Python script. For example, I loaded the official `Simple_Room` environment and generated preview images successfully.
This suggests that Isaac Sim itself, Vulkan rendering, and basic GPU access are working.
### 2. Host-side NVENC works
Independent NVENC test on the host succeeds on GPU 1:
```bash
ffmpeg -hide_banner -y \
-f lavfi -i testsrc2=size=640x360:rate=15 \
-t 2 \
-c:v h264_nvenc \
-gpu 1 \
-preset p1 \
/tmp/nvenc_gpu1_test_output
This suggests the target GPU has working hardware video encoding outside Isaac Sim.
### 3. Explicit NVIDIA capabilities and `/dev/nvidia-caps`
I tested:
```text
The error remains:
```text
### 4. X11 / virtual display experiment
I tried creating an X server on the host:
```bash
sudo nvidia-xconfig \
–allow-empty-initial-configuration \
--use-display-device=None \
–virtual=1280x720
sudo Xorg :1 -noreset +extension GLX +extension RANDR +extension RENDER
`DISPLAY=:1 xdpyinfo` worked, but `nvidia-smi -i 1 -q` still showed:
```text
I also tried:
```bash
--use-display-device=DFP-0 \
–connected-monitor=DFP-0 \
--virtual=1280x720
The display state still remained inactive, and Isaac Sim livestream still failed with the same StreamSDK error.
### 5. RTSP counter-test
I also tried RTSP streaming:
```bash
–enable omni DOT kit DOT livestream DOT rtsp \
--/exts/omni DOT kit DOT livestream DOT app/primaryStream/streamType=rtsp \
–/exts/omni DOT kit DOT livestream DOT app/primaryStream/streamPort=8554 \
That failed differently:
```text
Could not find nvh264enc element.
Failed to start the primary stream server
The plugin file exists:
```text
Isaac Sim RTSP extension plugin directory, file `libgstnvenc` shared object
`ldd` did not report missing dependencies. I also tried setting `GST_PLUGIN_PATH`, `GST_PLUGIN_SYSTEM_PATH_1_0`, and `LD_LIBRARY_PATH`, but RTSP still reported missing `nvh264enc`.
## Questions
1. Is Isaac Sim 6.0.0 WebRTC livestream expected to work on a remote headless Docker server with GeForce RTX 4090 GPUs and no physical display devices?
2. Does the Stream SDK require an active NVIDIA display on Linux for WebRTC livestream, even when Isaac Sim is started with `runheadless.sh`?
3. Is `Display Active: Disabled` expected to cause:
```text
4. If this environment should be supported, what exact driver/container/Xorg/NVENC/NVFBC settings are required?
5. Is there a known Isaac Sim 6.0.0 regression in WebRTC livestream on headless Docker compared with Isaac Sim 5.1.0?
6. Are there recommended diagnostics for `omni DOT kit DOT livestream DOT streamsdk` to determine whether the failure is caused by display mode, NVENC, NVFBC, Vulkan, or container device permissions?
## Logs Available
I can provide the full logs if needed. The most relevant local logs are:
```text
webrtc default 640x360 log
rtsp 640x360 log
rtsp 640x360 with GST path log
Isaac Sim Streaming/6.0 kit logs under /isaac-sim/.nvidia-omniverse/logs/Kit/
