Any updates on this topic? @sheikh-nv
When I run the webrtc with the --/app/livestream/logLevel=verboseoption, I get the following errors during startup which I believe to be related to webrtc:
2023-06-01 07:32:09 [5,265ms] [Warning] [omni.services.transport.server.http.server] http server was meant to start on 8211 but port is taken, starting on port 8068 instead
[5.298s] [ext: omni.kit.livestream.webrtc-0.1.0] startup
Active user not found. Using default user [kiosk]2023-06-01 07:32:09 [5,288ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #6(M)[2023-06-01 07:32:09,419]=07:32:09=00000{1493626207712371803}&CC7C5461& Computing SPS/PPS headers.
2023-06-01 07:32:09 [5,288ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: VideoFrameContext: #7(W)[2023-06-01 07:32:09,419]=07:32:09=00000{1493626207712371803}&0564BB28& Couldn’t find VideoFrameContext for this thread.
2023-06-01 07:32:09 [5,288ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #9(M)[2023-06-01 07:32:09,419]=07:32:09=00000{1493626207712371803}&1E959A86& Initializing Adapter context
2023-06-01 07:32:09 [5,288ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #2(M)[2023-06-01 07:32:09,419]=07:32:09=00000{1493626207712371803}&F0E847F4& Initialized context for adapter 0: 1280 x 720 @ 60.0 Hz
2023-06-01 07:32:09 [5,288ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #4(M)[2023-06-01 07:32:09,419]=07:32:09=00000{1493626207712371803}&9A64D99C& System is NOT co-proc.
2023-06-01 07:32:09 [5,337ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #5(M)[2023-06-01 07:32:09,469]=07:32:09=00049{1493626207712371803}&21C9B327& GPU memory usage: used = 12972.062500, free = 35696.500000 MB, total = 48668.562500 MB
2023-06-01 07:32:09 [5,338ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #6(M)[2023-06-01 07:32:09,469]=07:32:09=00000{1493626207712371803}&DD40CDEB& Initialized CUDA for device ‘NVIDIA RTX A6000’ (SM 8.6) in compute mode ‘CU_COMPUTEMODE_DEFAULT’.
2023-06-01 07:32:09 [5,338ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: VideoEncoder: #8(M)[2023-06-01 07:32:09,469]=07:32:09=00000{1493626207712371803}&8BAD092A& Initializing NvEnc10VideoEncoder.
2023-06-01 07:32:09 [5,338ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #9(M)[2023-06-01 07:32:09,469]=07:32:09=00000{1493626207712371803}&2A6D6983& Using NvEnc header version 10.0.
2023-06-01 07:32:09 [5,342ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #0(W)[2023-06-01 07:32:09,474]=07:32:09=00000{1493626207712371803}&7F9BD44D& Video format not supported, skipping preset.
2023-06-01 07:32:09 [5,343ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #2(W)[2023-06-01 07:32:09,474]=07:32:09=00000{1493626207712371803}&7F9BD44D& Video format not supported, skipping preset.
2023-06-01 07:32:09 [5,343ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #4(W)[2023-06-01 07:32:09,474]=07:32:09=00000{1493626207712371803}&7F9BD44D& Video format not supported, skipping preset.
2023-06-01 07:32:09 [5,343ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #6(W)[2023-06-01 07:32:09,474]=07:32:09=00000{1493626207712371803}&7F9BD44D& Video format not supported, skipping preset.
2023-06-01 07:32:09 [5,343ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #8(W)[2023-06-01 07:32:09,474]=07:32:09=00000{1493626207712371803}&7F9BD44D& Video format not supported, skipping preset.
2023-06-01 07:32:09 [5,343ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #0(W)[2023-06-01 07:32:09,474]=07:32:09=00000{1493626207712371803}&7F9BD44D& Video format not supported, skipping preset.
2023-06-01 07:32:09 [5,343ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #1(M)[2023-06-01 07:32:09,474]=07:32:09=00000{1493626207712371803}&21C9B327& GPU memory usage: used = 12972.062500, free = 35696.500000 MB, total = 48668.562500 MB
2023-06-01 07:32:09 [5,367ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: VideoEncoder: #5(W)[2023-06-01 07:32:09,499]=07:32:09=00000{1493626207712371803}&FB11B4FE& VideoEncoder was not deinitialized prior to destruction!
2023-06-01 07:32:09 [5,367ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEncUtil: #6(M)[2023-06-01 07:32:09,499]=07:32:09=00000{1493626207712371803}&B4368309& Finished computing SPS/PPS headers.
2023-06-01 07:32:09 [5,368ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: Signaling: #1(M)[2023-06-01 07:32:09,499]=07:32:09=00000{8167984385094387598}&1165739F& Signaling server started.
Streaming server started.
And then the following errors when I try to connect from a browser:
2023-06-01 07:35:02 [178,457ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #0(M)[2023-06-01 07:35:02,588]=07:35:02=00000{8167984385094387598}&1E959A86& Initializing Adapter context
2023-06-01 07:35:02 [178,457ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #3(M)[2023-06-01 07:35:02,588]=07:35:02=00000{8167984385094387598}&F0E847F4& Initialized context for adapter 0: 1280 x 720 @ 60.0 Hz
2023-06-01 07:35:02 [178,457ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #5(M)[2023-06-01 07:35:02,589]=07:35:02=00000{8167984385094387598}&9A64D99C& System is NOT co-proc.
2023-06-01 07:35:02 [178,522ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #1(M)[2023-06-01 07:35:02,654]=07:35:02=00065{8167984385094387598}&21C9B327& GPU memory usage: used = 7742.875000, free = 40925.687500 MB, total = 48668.562500 MB
2023-06-01 07:35:02 [178,522ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: AdapterContext: #2(M)[2023-06-01 07:35:02,654]=07:35:02=00000{8167984385094387598}&DD40CDEB& Initialized CUDA for device ‘NVIDIA RTX A6000’ (SM 8.6) in compute mode ‘CU_COMPUTEMODE_DEFAULT’.
2023-06-01 07:35:02 [178,523ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #8(W)[2023-06-01 07:35:02,654]=07:35:02=00000{11115815066630238539}&00000000& (pacing_controller.cc:154): Pacer min_packet_limit_2 disable_pacing_ 0
2023-06-01 07:35:02 [178,523ms] [Error] [carb.livestream-rtc.plugin] StreamSDK: PeerInstance: #8(E)[2023-06-01 07:35:02,655]=07:35:02=00000{8167984385094387598}&CBFBF6A7& (Peer ID: 2) OnRenegotiationNeeded
2023-06-01 07:35:02 [178,524ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #0(W)[2023-06-01 07:35:02,655]=07:35:02=00000{8167984385094387598}&00000000& (used_ids.h:55): Duplicate id found. Reassigning from 96 to 127
2023-06-01 07:35:02 [178,524ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #1(W)[2023-06-01 07:35:02,655]=07:35:02=00000{8167984385094387598}&00000000& (used_ids.h:55): Duplicate id found. Reassigning from 98 to 126
2023-06-01 07:35:02 [178,524ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #2(W)[2023-06-01 07:35:02,655]=07:35:02=00000{8167984385094387598}&00000000& (used_ids.h:55): Duplicate id found. Reassigning from 100 to 125
2023-06-01 07:35:02 [178,524ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #3(W)[2023-06-01 07:35:02,655]=07:35:02=00000{8167984385094387598}&00000000& (used_ids.h:55): Duplicate id found. Reassigning from 102 to 124
2023-06-01 07:35:02 [178,540ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: VideoEncoder: #7(M)[2023-06-01 07:35:02,672]=07:35:02=00000{11115815066630238539}&8BAD092A& Initializing NvEnc10VideoEncoder.
2023-06-01 07:35:02 [178,540ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #8(M)[2023-06-01 07:35:02,672]=07:35:02=00000{11115815066630238539}&2A6D6983& Using NvEnc header version 10.0.
2023-06-01 07:35:02 [178,543ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #4(M)[2023-06-01 07:35:02,675]=07:35:02=00000{11115815066630238539}&A88A086D& Max number of reference frames configured 4 for 1920x1080 at frame: 0
2023-06-01 07:35:02 [178,543ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #5(M)[2023-06-01 07:35:02,675]=07:35:02=00000{11115815066630238539}&A08C34AC& H264 video format selected
2023-06-01 07:35:02 [178,543ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #6(M)[2023-06-01 07:35:02,675]=07:35:02=00000{11115815066630238539}&B5A73036& RateControl mode NV_ENC_PARAMS_RC_CBR is selected for 1080@60 at frame: 0
2023-06-01 07:35:02 [178,543ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #7(M)[2023-06-01 07:35:02,675]=07:35:02=00000{11115815066630238539}&E96C44F6& Multi pass encoding configured as NV_ENC_TWO_PASS_QUARTER_RESOLUTION at frame: 0
2023-06-01 07:35:02 [178,544ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #0(M)[2023-06-01 07:35:02,675]=07:35:02=00000{11115815066630238539}&4961242A& Encoder preset configured PRESET_LOW_LATENCY_HP
2023-06-01 07:35:02 [178,544ms] [Fatal] [carb.livestream-rtc.plugin] StreamSDK: NvEnc10VideoEncoder: #1(M)[2023-06-01 07:35:02,675]=07:35:02=00000{11115815066630238539}&C15E78BB& Encoder preset used PRESET_NVENC_P3
2023-06-01 07:35:02 [178,572ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #7(W)[2023-06-01 07:35:02,704]=07:35:02=00000{11115815066630238539}&00000000& (balanced_degradation_settings.cc:96): Unsupported size, value ignored.
2023-06-01 07:35:02 [178,572ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #8(W)[2023-06-01 07:35:02,704]=07:35:02=00000{11115815066630238539}&00000000& (balanced_degradation_settings.cc:96): Unsupported size, value ignored.
2023-06-01 07:35:02 [178,572ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #9(W)[2023-06-01 07:35:02,704]=07:35:02=00000{11115815066630238539}&00000000& (balanced_degradation_settings.cc:96): Unsupported size, value ignored.
2023-06-01 07:35:02 [178,573ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #4(W)[2023-06-01 07:35:02,704]=07:35:02=00000{17797842939666438197}&00000000& (forward_error_correction.cc:95): FEC encode configuration, min_fec_packets: 0 max_fec_packets: 48
2023-06-01 07:35:02 [178,573ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #3(W)[2023-06-01 07:35:02,704]=07:35:02=00000{17797842939666438197}&00000000& (rtp_video_sender.cc:107): Transmitting payload type without picture ID using NACK+ULPFEC is a waste of bandwidth since ULPFEC packets also have to be retransmitted. Disabling ULPFEC.
2023-06-01 07:35:02 [178,586ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #6(W)[2023-06-01 07:35:02,717]=07:35:02=00010{16530539155952229181}&00000000& (p2p_transport_channel.cc:1247): Failed to resolve ICE candidate hostname 87e9305f-2f75-450c-8083-5303f887b4e1.local with error -2
2023-06-01 07:35:02 [178,586ms] [Warning] [carb.livestream-rtc.plugin] StreamSDK: WebRtc: #7(W)[2023-06-01 07:35:02,717]=07:35:02=00000{16530539155952229181}&00000000& (thread.cc:807): Waiting for the thread to join, but blocking calls have been disallowed
