IsaacSim livestreaming container with 525.125 driver
I’m running a Singularity container on a server with RTX 2080 Ti, CUDA 12.0, and the driver version 525.125.06. Having observed the Isaac Sim Headless Native App is loaded., I open the Omniverse livestreaming client and connect via an IP address of the server. After several seconds of waiting, the error code I observed was:
The only error in the logs is due to the failed creation of the NGX context:
2023-10-19 20:54:08 [87,945ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register LdrColor, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,945ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register DistanceToImagePlane, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,945ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register DistanceToCamera, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,945ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register Camera3dPosition, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,945ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register Normal, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,945ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register CrossCorrespondence, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register TargetMotion, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register InstanceIdSegmentation, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register InstanceSegmentation, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register SemanticSegmentation, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register SemanticIdSegmentation, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register BoundingBox2DTight, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register BoundingBox2DLoose, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register BoundingBox3D, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register <omni.kit.viewport.menubar.core.menu_item.viewport_menu_separator.ViewportMenuSeparator object at 0x7fcd160cd230>, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register Clear All, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [87,946ms] [Info] [omni.kit.viewport.menubar.core.viewport_menu_model] register Show Window, order: -1, parent: SyntheticData
2023-10-19 20:54:08 [88,034ms] [Warning] [omni.client.plugin]  117965: omniclient: Cannot stat root directory (URI: plus.40x40.png)
2023-10-19 20:54:08 [88,039ms] [Warning] [omni.client.plugin]  117956: omniclient: Cannot stat root directory (URI: save.40x40.png)
2023-10-19 20:54:08 [88,045ms] [Warning] [omni.client.plugin]  118018: omniclient: Cannot stat root directory (URI: settings.40x40.png)
2023-10-19 20:54:08 [88,073ms] [Info] [omni.kit.menu.utils.scripts.utils] omni.kit.menu.utils.refresh_menu_items Tools
2023-10-19 20:54:08 [88,123ms] [Warning] [omni.client.plugin]  117939: omniclient: Cannot stat root directory (URI: physics_placement_toolbar.56x56.png)
2023-10-19 20:54:08 [88,130ms] [Warning] [omni.client.plugin]  117996: omniclient: Cannot stat root directory (URI: paint_dark.56x56.png)
2023-10-19 20:54:08 [88,257ms] [Info] [carb] Initializing plugin: omni.gpucompute-cuda.plugin (interfaces: [omni::gpucompute::GpuCompute v0.1]) (impl: omni.gpucompute-cuda.plugin)
2023-10-19 20:54:08 [88,259ms] [Info] [carb] Plugin omni.anim.curve.plugin is already a dependency of omni.kit.app.plugin; not changing unload order
2023-10-19 20:54:08 [88,261ms] [Info] [carb] Initializing plugin: omni.hydra.scene_delegate.plugin (interfaces: [carb::fastcache::FastCache v0.4],[carb::fastcache::FastCacheHydra v0.2],[omni::hydra::IDebug v0.1],[omni::hydra::IOmniHydra v2.0],[omni::hydra::ISceneDelegateFactory v0.1]) (impl: omni.hydra.scene_delegate.plugin)
2023-10-19 20:54:08 [88,793ms] [Info] [carb.graphics-vulkan.plugin] Active GPU: NVIDIA GeForce RTX 2080 Ti
2023-10-19 20:54:09 [88,870ms] [Info] [carb] Initializing plugin: omni.gpucompute-d3dvk.plugin (interfaces: [omni::gpucompute::ComputeCompiler v0.1],[omni::gpucompute::GpuCompute v0.1]) (impl: omni.gpucompute-d3dvk.plugin)
2023-10-19 20:54:09 [88,870ms] [Info] [carb.flowusd.plugin] Attaching Flow USD plugin: 9223001
2023-10-19 20:54:09 [88,882ms] [Info] [carb] Initializing plugin: carb.volume.plugin (interfaces: [carb::volume::IVolume v0.1]) (impl: carb.volume.plugin)
2023-10-19 20:54:09 [88,925ms] [Info] [omni.usd.audio] refreshing the USD scene state
2023-10-19 20:54:09 [88,960ms] [Info] [carb.audio.output] {speakers = 0x00000003, map = 0x7ffeaecf1260}
2023-10-19 20:54:09 [88,963ms] [Info] [omni.usd.audio] initial audio volumes: (1.00, 1.00, 1.00)
2023-10-19 20:54:09 [89,156ms] [Info] [carb] Initializing plugin: carb.scenerenderer-rtx.plugin (interfaces: [carb::renderer::SceneRenderer v6.1]) (impl: carb.scenerenderer-rtx.plugin)
2023-10-19 20:54:09 [89,163ms] [Info] [carb] Initializing plugin: carb.scenerenderer-iray.plugin (interfaces: [carb::renderer::SceneRenderer v6.1]) (impl: carb.scenerenderer-iray.plugin)
2023-10-19 20:54:09 [89,192ms] [Info] [gpu.foundation.plugin] The list of unsupported driver ranges being verified with known bugs (RTX):
[0.0, 470.121)
[495.0, 510.58)
[515.0, 515.17)
The recommended drivers: 525.85.05 (GameReady, Studio, RTX/Quadro), 525.85.12 (Grid/vGPU)
The latest driver version may also work but is not fully tested.
2023-10-19 20:54:09 [89,192ms] [Info] [carb] Initializing plugin: rtx.multigpumanager.plugin (interfaces: [rtx::multigpumanager::MultiGpuManager v0.8]) (impl: rtx.multigpumanager.plugin)
2023-10-19 20:54:09 [89,195ms] [Info] [carb] Initializing plugin: rtx.scenedb.plugin (interfaces: [rtx::scenedb::SceneDb v1.2]) (impl: rtx.scenedb.plugin)
2023-10-19 20:54:09 [89,212ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/database/DirtyPageCopy.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,213ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/database/DirtyElementsCopy.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,249ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/SparseMemCopy.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,249ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/utils/PrefixScanBuffer.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,249ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/utils/PrefixScanTexture.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,251ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,251ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,277ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,278ms] [Info] [carb.graphics-vulkan.plugin] plugins rev1 path: /isaac-sim/kit/extscore/omni.gpu_foundation/bin/deps/rev1
2023-10-19 20:54:09 [89,278ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,278ms] [Info] [carb] Initializing plugin: carb.graphics_optional.plugin (interfaces: [carb::graphics::IOptionalFeatures v2.0]) (impl: carb.graphics_optional.plugin)
2023-10-19 20:54:09 [89,278ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/filters/LowPass.cs.hlsl' does not exist
2023-10-19 20:54:09 [89,279ms] [Info] [carb.graphics-vulkan.plugin] carb.graphics optional features library path: /isaac-sim/kit/extscore/omni.gpu_foundation/bin/deps
2023-10-19 20:54:09 [89,281ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl' does not exist
2023-10-19 20:54:09 [89,288ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl' does not exist
2023-10-19 20:54:09 [89,289ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl' does not exist
2023-10-19 20:54:09 [89,289ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/TranslateInstancePosition.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,290ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/ValidateSbt.compute.hlsl' does not exist
2023-10-19 20:54:09 [89,290ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/ProceduralAabb.comp.hlsl' does not exist
2023-10-19 20:54:09 [89,290ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/Skinning.comp.hlsl' does not exist
2023-10-19 20:54:09 [89,290ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/SkinNormal.comp.hlsl' does not exist
2023-10-19 20:54:09 [89,291ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/NormalGeneration.comp.hlsl' does not exist
2023-10-19 20:54:09 [89,291ms] [Info] [carb] file '/isaac-sim/kit/shaders/rtx/scenedb/VertexPulling.comp.hlsl' does not exist
2023-10-19 20:54:09 [89,296ms] [Info] [carb.graphics-vulkan.plugin] Failed to initialize NGX on GPU: NVIDIA GeForce RTX 2080 Ti. Optional DLSS feature will be disabled for it.
2023-10-19 20:54:09 [89,296ms] [Error] [carb.graphics-vulkan.plugin] Could not get NGX parameters block because NGX isn't enabled.
2023-10-19 20:54:09 [89,296ms] [Error] [carb.graphics-vulkan.plugin] Failed to create NGX context.
2023-10-19 20:54:09 [89,296ms] [Warning] [carb.scenerenderer-rtx.plugin] Failed to create NGX context.
The original docker container works in a setup of 515.65.01 driver with CUDA 11.7 on a local machine. Could you help to troubleshoot the NGX error?
Hi. We currently do not support Singularity yet.
Can you provide instructions on how you setup and run the container?
Does nvidia-smi works in that container?
nvidia-smi works, its output is:
I build it from an official image:
docker save nvcr.io/nvidia/isaac-sim:2022.2.1 -o isaacsim.tar
singularity build --sandbox isaacsim docker-archive://isaacsim.tar
and start the following way:
singularity exec --nv --home /user/isaacsim/home \
    --bind /user/isaacsim/cache/kit:/isaac-sim/kit/cache/Kit:rw \
    --bind /user/isaacsim/cache/ov:/root/.cache/ov:rw \
    --bind /user/isaacsim/cache/pip:/root/.cache/pip:rw \
    --bind /user/isaacsim/cache/glcache:/root/.cache/nvidia/GLCache:rw \
    --bind /user/isaacsim/cache/computecache:/root/.nv/ComputeCache:rw \
    --bind /user/isaacsim/logs:/root/.nvidia-omniverse/logs:rw \
    --bind /user/isaacsim/data:/root/.local/share/ov/data:rw \
    --bind /user/isaacsim/documents:/root/Documents:rw \
    isaacsim sh
With 515.65.01 and CUDA 11.7, the same container launched on the localhost allows connecting to it via Omniverse Livestreaming. Although the NGX error remains.
The docker setup runs cleanly.
Thanks. Does the livestreaming work with the 515 drivers?
I am not sure if Vulkan is setup on our container to support Singularity. This could be the cause of the NGX errors.
Can you try install and run vulkaninfo?
Try this old topic too.
