RTX A6000 running isaac-sim container not able to connect with streaming client (GUI shows empty content)
I am running isaac-sim container on my cloud server instance. I can start isaac_sim using runheadless.native.sh. But I cannot see anything from the streaming client GUI (I can see log that Isaac Sim Headless is loaded). I realized there is an error when isaac_sim initializing on the server. I search online and cannot find a solution. The error:
2024-10-29 05:39:03 [27,120ms] [Error] [carb.graphics-vulkan.plugin] Could not get NGX parameters block because NGX isn’t enabled.
2024-10-29 05:39:03 [27,120ms] [Error] [carb.graphics-vulkan.plugin] Failed to create NGX context.
I also checked ports it’s listening. I don’t find those defined on the offical guide: 47995:48012 (TCP/UDP), 49000:49007 (TCP/UDP), 49100 TCP. Below are the context I grabbed in container,
tcp 0 0 127.0.0.1:61209 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:41821 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:7000 0.0.0.0:* LISTEN
tcp6 0 0 :::111 :::* LISTEN
tcp6 0 0 :::22 :::* LISTEN
I also tried the WebRTC method. I can start isaac-sim webrtc on server using runheadless.webrtc.sh. But I cannot see anything in my browser. I opened port 8211 TCP/UPD on my server. I used telnet to check whether the port is open. I don’t see any error, but found one info from log:
Tick: provider_nucleus: Connection to omniverse:// failed: No host specified
Isaac-Sim version
4.2.0 container
Operating system
Ubuntu 22.04
GPU Model
RTX A6000
GPU Driver (both linux server and docker image)
550.120 (tried 535, 560 as well)
Vulkan API Version
1.3.204. I also tried vulkaninfo | grep “Device Name”, no GPU detected and below is the output
WARNING: [Loader Message] Code 0 : terminator_CreateInstance: Failed to CreateInstance in ICD 4.  Skipping ICD.
Kernel Version
6.8.0-47-generic
Steps to Reproduce
I am following this link: https://docs.omniverse.nvidia.com/isaacsim/latest/installation/install_container.html
Screenshots or Videos (Headless Native)
Screenshots or Videos (WebRTC)
Related Issues
Tried A100 as well. But it doesn’t support graphics well. So switched to RTX A6000.
Are you follow Container Installation to use Docker container?
Yes, I follow this link using docker container.
I also tried IsaacLab LiveStream (both Streaming Client & WebRTC), also not working: [Bug Report] Not able to use LiveStream and Streaming CLient · Issue #1399 · isaac-sim/IsaacLab · GitHub.
For WebRTC, must I need to install the extension? I didn’t find a way to install Omniverse on macbook.
Please check the following documentation: Linux Troubleshooting and try reinstalling the suggested drivers. Additionally, follow Container Installation — Omniverse IsaacSim to reinstall Docker and the latest container toolkit.
"vulkaninfo | grep “Device Name” seems to be a wrong command for checking. I tried "vulkaninfo | grep “GPU” and can find the GPU device. I also reinstall Cuda, driver, vulkan, kernel many times. I don’t see any trivial mistake. I’ve followed Container Installation multiple times. I don’t know what else I can do.
I searched in the forum, and seems vulkan and driver don’t match is a common answer. For this case, what could be wrong? I’ve listed all version info.
Hi, can you share the output of nvidia-ctk --version?
If it is older than 1.16.2 please re-install/update the NVIDIA Container Tookit.
Try running these to test:
docker run --rm --runtime=nvidia --gpus all ubuntu nvidia-smi
docker run --name isaac-sim --runtime=nvidia --gpus all -e “ACCEPT_EULA=Y” --rm --network=host -e “PRIVACY_CONSENT=Y” nvcr.io/nvidia/isaac-sim:4.2.0
Thanks for the response. Unfortunately, I didn’t figure out the solution for a while. So I cancelled the A6000 instance last week. Now I have a new A10 instance. Does it work for isaac sim and local GUI? If so, I will give another try and use your advises.
I believe the A6000 should be supported, but you can go ahead and try the A10.
