Isaac-sim crashes when loading URDF from VS-code
Hi everyone,
I am working on AWS g6.2xlarge instance with isaac-sim 4.5.0 docker. I installed RealVNC and X11 necessary to get visuals of the instance and I was also using webRTC to get visuals
from “./runheadless.sh -v”
I have also installed Isaac-sim VS code edition, installed its extnsion and trying to run urdf_import.py from folder standalone_example/api/
I am running this code line by line and also all at once, at urdf isaac-sim stops in webRTC and in terminal “Stream Server: stream0 0x7f83fc2ad690 (type 1) stopped”,
import omni.kit.commands
from isaacsim.core.prims import Articulation
from isaacsim.core.utils.extensions import get_extension_path_from_name
from pxr import Gf, PhysxSchema, Sdf, UsdLux, UsdPhysics
status, import_config = omni.kit.commands.execute(“URDFCreateImportConfig”)
import_config.merge_fixed_joints = False
import_config.convex_decomp = False
import_config.import_inertia_tensor = True
import_config.fix_base = False
import_config.distance_scale = 1.0
scene = UsdPhysics.Scene.Define(stage, Sdf.Path(“/physicsScene”))
scene.CreateGravityDirectionAttr().Set(Gf.Vec3f(0.0, 0.0, -1.0))
scene.CreateGravityMagnitudeAttr().Set(9.81)
PhysxSchema.PhysxSceneAPI.Apply(stage.GetPrimAtPath(“/physicsScene”))
physxSceneAPI = PhysxSchema.PhysxSceneAPI.Get(stage, “/physicsScene”)
#… and other physxscene settings all run well “executed without output”
“AddGroundPlaneCommand”,
stage=stage,
planePath=“/groundPlane”,
axis=“Z”,
size=1500.0,
position=Gf.Vec3f(0, 0, -0.50),
color=Gf.Vec3f(0.5),
extension_path = get_extension_path_from_name(“isaacsim.asset.importer.urdf”)
status, prim_path = omni.kit.commands.execute(
“URDFParseAndImportFile”,
urdf_path=extension_path + “/data/urdf/robots/carter/urdf/carter.urdf”,
import_config=import_config,
get_articulation_root=True,
I tried other URDFs too. Can you please help me with this issue.
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: L4
  • Driver Version: Nvidia 570
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Steps to Reproduce
  1. AWS instance + 4.5.0 docker
  2. ./runheadless.sh -v + webRTC client launch
  3. Isaac-sim VS code edition > /isaac-sim/stand-alone-examples/api/import_urdf.py
  4. Run it whole or line by line when I execute urdf part, isaac sim crashes in WebRTC with msg in its terminal
    Stream Server: stream0 0x7fa33c307090 (type 1) stopped
Do you still have this problem? Are you running Isaac Sim WebRTC Streaming Client within the same network?
Hello!
Best regards,
