Isaac sim new streaming client
Isaac Sim Version
4.5.0
Operating System
Other (windows server 2022):
GPU Information
  • Model: A10G
  • Driver Version: 572.16
Topic Description
Detailed Description
I am using an AWS EC2 instance of type g5.2xlarge. I have installed and run the new version of IsaacSim (4.5.0) from the isaacsim app selector. I run the isaac sim full streaming and when I ‘connect’ with the new streaming client (Isaac Sim WebRTC Streaming Client 1.0.6) from the same instance where isaac sim runs, it works. When I
try to connect from my local laptop (where I have also installed the new streaming client) the screen just stays black. The security group of the instance is allowing all traffic, all ports towards my IP.
Also when I ‘connect’ the streaming client from the instance itself, on the cmd windows it shows the ‘connection’ attempt but when I try from local laptop, it does not.
What operating system is installed on your local laptop? If it’s Windows, could you try using Ubuntu, and vice versa?
Please refer to this note from AWS Deployment — Isaac Sim Documentation to switch to the deprecated client for your setup.
  1. Download and install the Omniverse Streaming Client [DEPRECATED] from the Latest Release section.
Note
  • Isaac Sim WebRTC Streaming Client may not work to connect to an EC2 instance over the Internet.
Additionally, this topic is relevant:
Then what is the purpose of WebRTC streaming client in this new version?
Problems related to the Internet couldn’t be resolved before the release. Therefore, under these circumstances.
Hi. The Isaac Sim WebRTC Streaming Client will be replacing the Omniverse Streaming Client.
