GPU Information
- Model: Nvidia H100 NVL
- Driver Version: 550.163.01
Topic Description
Isaac Sim support on H100 GPU without RT Cores
Detailed Description
I am planning to use NVIDIA Isaac Sim with the Newton physics engine on an NVIDIA H100 GPU for the following robotics simulations:
🚤 Autonomous boat simulation
🤖 All-terrain autonomous mobile robot simulation
My primary focus is on:
ROS 2 integration
Navigation and autonomy stack testing
Physics simulation
Terrain interaction and mobility testing
While researching, I found that the NVIDIA H100 does not contain RT Cores, which are typically required for RTX-based sensors such as:
RTX LiDAR
RTX Radar
RTX Camera sensors
So before deploying my workloads, I wanted to clarify:
Can Isaac Sim + Newton Physics run properly on H100 without RTX sensor support?
Are there any non-RTX alternatives available for LiDAR/Radar simulation?
Is H100 suitable mainly for physics, AI compute, and robotics autonomy workloads in Isaac Sim?
Expected Behavior
- I expect Isaac Sim and Newton Physics to work correctly for robotics simulation workloads even if RTX sensor functionality is limited or unavailable.
- I am also comfortable running Isaac Sim in headless mode if that is the recommended approach for H100-based deployments.
Actual Concern
Potential incompatibility or limited functionality of RTX-based sensors due to absence of RT Cores on H100 GPUs.
Additional Information
The simulations are intended for:
- Autonomous Surface Vehicles (ASV)
- Unmanned Ground Vehicles (UGV)
- ROS 2 based autonomy stack testing
