My system: 13600k, 64gig ram, 3060 12 gigs, Ubuntu driver 525.147
First I installed Isaac sim conda environment issac-sim using the given document which is working perfectly Python Environment Installation — Omniverse IsaacSim latest documentation
Then I followed the instructions here step by step from here:
Installation Guide — orbit documentation
but I have encountered an error regarding no omni isaac found so I source ~/.local/share/ov/pkg/isaac_sim-2023.1.1/setup_conda_env.sh in my orbit conda environment as well.
When I run the script using ./orbit.sh -p source/standalone/demos/quadrupeds.py for instance isaac would be opened and freeze on this line of code:
[5.606s] Simulation App Starting
2024-02-15 16:39:04 [5,617ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/ecoMode/enabled has been requested but is not available
2024-02-15 16:39:04 [5,617ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/directLighting/enabled has been requested but is not available
2024-02-15 16:39:04 [5,617ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/reflections/enabled has been requested but is not available
2024-02-15 16:39:04 [5,617ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/translucency/enabled has been requested but is not available
2024-02-15 16:39:04 [5,617ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/raytracing/subsurface/enabled has been requested but is not available
2024-02-15 16:39:04 [5,617ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/caustics/enabled has been requested but is not available
2024-02-15 16:39:05 [6,726ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2024-02-15 16:39:05 [6,726ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[7.472s] app ready
2024-02-15 16:39:06 [7,715ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2024-02-15 16:39:06 [7,715ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[7.839s] RTX ready
[8.054s] Simulation App Startup Complete
2024-02-15 16:39:27 [28,094ms] [Warning] [omni.client.python] Detected a blocking function. This will cause hitches or hangs in the UI. Please switch to the async version:
File “/home/amirhossein/Documents/GitHub/orbit/source/standalone/demos/quadrupeds.py”, line 45, in
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/home/amirhossein/Documents/GitHub/orbit/source/extensions/omni.isaac.orbit/omni/isaac/orbit/sim/init.py”, line 29, in
File “/home/amirhossein/Documents/GitHub/orbit/source/extensions/omni.isaac.orbit/omni/isaac/orbit/sim/converters/init.py”, line 20, in
File “/home/amirhossein/Documents/GitHub/orbit/source/extensions/omni.isaac.orbit/omni/isaac/orbit/sim/converters/asset_converter_base.py”, line 17, in
File “/home/amirhossein/Documents/GitHub/orbit/source/extensions/omni.isaac.orbit/omni/isaac/orbit/utils/assets.py”, line 27, in
File “/home/amirhossein/.local/share/ov/pkg/isaac_sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/utils/nucleus.py”, line 572, in get_assets_root_path
File “/home/amirhossein/.local/share/ov/pkg/isaac_sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/utils/nucleus.py”, line 192, in check_server
File “/home/amirhossein/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/extscore/omni.client/omni/client/init.py”, line 158, in stat
I have also tested :
this example is just a simple stage so there is no asset there:
Copyright (c) 2022-2024, The ORBIT Project Developers.
All rights reserved.
SPDX-License-Identifier: BSD-3-Clause
“”"This script demonstrates how to create a simple stage in Isaac Sim.
… code-block:: bash
# Usage
./orbit.sh -p source/standalone/tutorials/00_sim/create_empty.py
from future import annotations
“”“Launch Isaac Sim Simulator first.”“”
But I am encountering the same error mesaage
Hi @ahn.paf - Can you confirm that you are following this documentation for installing Orbit?
https://isaac-orbit.github.io/orbit/source/setup/installation.html
I managed to solve the problem and run the first example by logging in to nucleus, but that was the only time it worked. After that, my Isaac sim 2023 broke down completely. I think it has something to do with the python path, because I couldn’t run Isaac sim or OIGE properly, and I reported it in another post.
Another problem that I still have is that my Isaac sim freezes at this line, no matter which example I try to run. That’s very odd.
Because of these issues, I uninstalled Isaac 2023 and reinstalled it, and now everything works fine without orbit.
Do you think I should try orbit again? Do I need to source the Isaac folder every time I run Isaac using conda? I don’t think this is related, but I also suspect that orbit has a big performance problem, at least for me.
I have forward your question to devs. They will review the issue and provide further instructions.
To me, this issue seems to be because of Nucleus connection. If that is not happening properly, then Isaac Sim does a “search” over all possible paths and tries to connect to multiple different servers until it finds one that it can connect to. Please make sure you check the Isaac Sim instructions on connecting Nucleus.
