Issue UEFI boot with re-flashing JetPack 5.1.2 on Orin NX (Previously Flashed with JetPack 5.1.5)
Hi.
I’ve got exactly same issue as in the following topic Issue Flashing JetPack 5.1.2 on Orin NX (Previously Flashed with JetPack 6.2) but after moving from Jetpack-5.1.2 to recent Jetpack-5.1.5 instead. It seems that I could not go back to Jetpack-5.1.2 with the following log :
flash_3-1_0_20250611-223722.log (40.9 KB)
If I re-flashed with Jetpack-5.1.5, it became okay with the UEFI boot:
flash_3-1_0_20250611-224712.log (40.7 KB)
My plan is changing to a new NVMe SSD and trying again with Jetpack-5.1.2.
Best Regards,
K
It looks like both logs telling us it is successful. Are you sure this is correct log?
Yes, I confrim they are correct logs: they were successful during the flashing but then issue with the UEFI boot-up for Jetpack-5.1.2:
L4TLauncher: Failed to get PlatformResourceInfo
This might also happen when migrating from older Jetpack (including Jetpack-5.1.5) to the Jetpack-6.2 as well if I remember correctly and I was thinking that my NVMe SSD was broken.
Update : Re-flashing Jetpack-5.1.2 with a brand new NVMe SSD passed the UEFI and went to the Ubuntu for the System Configuration. The log :
flash_3-1_0_20250611-232052.log (41.0 KB)
So it looks like for the current situation, if an NVME SSD was flashed with Jetpack-5.1.5 or Jetpack-6.2, they could only be re-flashed with same or posterior Jetpack releases.
~0702
Please share us the full boot up log to check.
