Issue with CSI Datastream (Multi Bit Error, tegra_channel_error_status, frame start syncpt timeout!0)
I am streaming data from a FPGA via the CAM0/1 port on the Xavier NX devkit into the Xavier. (See device tree below)
Used device tree Xavier NX (mode1)
 * Copyright (c) 2018-2020, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <dt-bindings/media/camera.h>
	host1x {
		vi@15c10000  {
			num-channels = <1>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				vi_port0: port@0 {
					reg = <0>;
					liimx185_vi_in0: endpoint {
						port-index = <0>;
						bus-width = <2>;
						remote-endpoint = <&liimx185_csi_out0>;
		nvcsi@15a00000 {
			num-channels = <1>;
			#size-cells = <0>;
			csi_chan0: channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					csi_chan0_port0: port@0 {
						reg = <0>;
						liimx185_csi_in0: endpoint@0 {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&liimx185_imx185_out0>;
					csi_chan0_port1: port@1 {
						reg = <1>;
						liimx185_csi_out0: endpoint@1 {
							remote-endpoint = <&liimx185_vi_in0>;
	cam_i2cmux {
		i2c_0:i2c@0 {
			imx185_cam0: rbpcv2_imx185_a@1a {
				compatible = "nvidia,imx185";
				/* I2C device address */
				reg = <0x1a>;
				clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>, <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>;
				clock-names = "extperiph1", "pllp_grtba";
				mclk = "extperiph1";
				clock-frequency = <24000000>;
				/* V4L2 device node location */
				devnode = "video0";
				/* Physical dimensions of sensor */
				physical_w = "15.0";
				physical_h = "10.0";
				sensor_model = "imx185";
				use_sensor_mode_id = "false";
				* ==== Modes ====
				* A modeX node is required to support v4l2 driver
				* implementation with NVIDIA camera software stack
				* == Signal properties ==
				* phy_mode = "";
				* PHY mode used by the MIPI lanes for this device
				* tegra_sinterface = "";
				* CSI Serial interface connected to tegra
				* Incase of virtual HW devices, use virtual
				* For SW emulated devices, use host
				* pix_clk_hz = "";
				* Sensor pixel clock used for calculations like exposure and framerate
				* readout_orientation = "0";
				* Based on camera module orientation.
				* Only change readout_orientation if you specifically
				* Program a different readout order for this mode
				* == Image format Properties ==
				* active_w = "";
				* Pixel active region width
				* active_h = "";
				* Pixel active region height
				* pixel_t = "";
				* The sensor readout pixel pattern
				* line_length = "";
				* Pixel line length (width) for sensor mode.
				* == Source Control Settings ==
				* Gain factor used to convert fixed point integer to float
				* Gain range [min_gain/gain_factor, max_gain/gain_factor]
				* Gain step [step_gain/gain_factor is the smallest step that can be configured]
				* Default gain [Default gain to be initialized for the control.
				*     use min_gain_val as default for optimal results]
				* Framerate factor used to convert fixed point integer to float
				* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
				* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
				* Default Framerate [Default framerate to be initialized for the control.
				*     use max_framerate to get required performance]
				* Exposure factor used to convert fixed point integer to float
				* For convenience use 1 sec = 1000000us as conversion factor
				* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
				* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
				* Default Exposure Time [Default exposure to be initialized for the control.
				*     Set default exposure based on the default_framerate for optimal exposure settings]
				* gain_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_gain_val = ""; (ceil to integer)
				* max_gain_val = ""; (ceil to integer)
				* step_gain_val = ""; (ceil to integer)
				* default_gain = ""; (ceil to integer)
				* Gain limits for mode
				* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_exp_time = ""; (ceil to integer)
				* max_exp_time = ""; (ceil to integer)
				* step_exp_time = ""; (ceil to integer)
				* default_exp_time = ""; (ceil to integer)
				* Exposure Time limits for mode (sec)
				* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
				* min_framerate = ""; (ceil to integer)
				* max_framerate = ""; (ceil to integer)
				* step_framerate = ""; (ceil to integer)
				* default_framerate = ""; (ceil to integer)
				* Framerate limits for mode (fps)
				* embedded_metadata_height = "";
				* Sensor embedded metadata height in units of rows.
				* If sensor does not support embedded metadata value should be 0.
				mode0 { /* 2048x128 */
					mclk_khz = "20000";
					num_lanes = "2";
					phy_mode = "DPHY";
					discontinuous_clk = "no";
					dpcm_enable = "false";
					cil_settletime = "0";
                                        dynamic_pixel_bit_depth = "12";
                                        csi_pixel_bit_depth = "12";
                                        mode_type = "bayer";
                                        pixel_phase = "rggb";
					active_w = "2048";
					active_h = "128";
					line_length = "2048";
					inherent_gain = "1";
					mclk_multiplier = "4";
					pix_clk_hz = "80000000";
					gain_factor = "1";
					framerate_factor = "1000000";
					exposure_factor = "1000000";
					min_gain_val = "0"; /* 0 dB */
					max_gain_val = "24"; /* 24 dB */
					step_gain_val = "1";
					default_gain = "0"; /* 0 dB */
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
					min_framerate = "10000000"; /* 10 fps */
					max_framerate = "100000000"; /* 100 fps */
					step_framerate = "1";
					default_framerate = "20000000"; /* 20 fps */
					min_exp_time = "10"; /* us */
					max_exp_time = "1000"; /* us */
					step_exp_time = "1";
					default_exp_time = "100"; /* us */
					embedded_metadata_height = "0";
				mode1 { /* 3648x2304 */
					mclk_khz = "20000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "3648";
					active_h = "2304";
					line_length = "3648";
					gain_factor = "1";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						liimx185_imx185_out0: endpoint {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&liimx185_csi_in0>;
	lens_imx185@RBPCV2 {
		min_focus_distance = "0.0";
		hyper_focal = "0.0";
		focal_length = "3.04";
		f_number = "2.0";
		aperture = "0.0";
	tcp: tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <2>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <12>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <240000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		 * The general guideline for naming badge_info contains 3 parts, and is as follows,
		 * The first part is the camera_board_id for the module; if the module is in a FFD
		 * platform, then use the platform name for this part.
		 * The second part contains the position of the module, ex. "rear" or "front".
		 * The third part contains the last 6 characters of a part number which is found
		 * in the module's specsheet from the vendor.
		modules {
			cam_module0: module0 {
				badge = "imx185_front_liimx185";
				position = "front";
				orientation = "0";
				cam_module0_drivernode0: drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "imx185 30-001a";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/rbpcv2_imx185_a@1a";
				cam_module0_drivernode1: drivernode1 {
					pcl_id = "v4l2_lens";
					proc-device-tree = "/proc/device-tree/lens_imx185@RBPCV2/";
This works without issue, but when I try to do the same thing on the NANO it does not work. (See dmesg and device tree below)
dmesg when streaming data via CAM1
[ 1207.567389] imx185 7-001a: camera_common_mclk_enable: enable MCLK with 20000000 Hz
[ 1207.575100] imx185 7-001a: camera_common_dpd_disable: csi 0
[ 1207.580741] imx185 7-001a: imx185_power_on: power on
[ 1207.585777] vi 54080000.vi: Calibrate csi port 0
[ 1207.585923] imx185 7-001a: imx185_power_off: power off
[ 1207.591159] imx185 7-001a: camera_common_dpd_enable: csi 0
[ 1207.596821] imx185 7-001a: camera_common_mclk_disable: disable MCLK
[ 1207.603160] imx185 8-001a: camera_common_mclk_enable: enable MCLK with 20000000 Hz
[ 1207.610816] imx185 8-001a: camera_common_dpd_disable: csi 4
[ 1207.616472] imx185 8-001a: imx185_power_on: power on
[ 1207.621468] vi 54080000.vi: Calibrate csi port 4
[ 1207.621591] imx185 8-001a: imx185_power_off: power off
[ 1207.626811] imx185 8-001a: camera_common_dpd_enable: csi 4
[ 1207.632327] imx185 8-001a: camera_common_mclk_disable: disable MCLK
[ 1207.638637] imx185 8-001a: camera_common_mclk_enable: enable MCLK with 20000000 Hz
[ 1207.646303] imx185 8-001a: camera_common_dpd_disable: csi 4
[ 1207.651947] imx185 8-001a: imx185_power_on: power on
[ 1207.658237] vi 54080000.vi: cil_settingtime was autocalculated
[ 1207.658243] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1207.859463] video4linux video1: frame start syncpt timeout!0
[ 1207.865661] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1207.865678] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1207.865693] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1207.865815] vi 54080000.vi: cil_settingtime was autocalculated
[ 1207.865833] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1208.067471] video4linux video1: frame start syncpt timeout!0
[ 1208.073724] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1208.073742] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1208.073757] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1208.074069] vi 54080000.vi: cil_settingtime was autocalculated
[ 1208.074095] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1208.275552] video4linux video1: frame start syncpt timeout!0
[ 1208.281587] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1208.281636] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1208.281681] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1208.281894] vi 54080000.vi: cil_settingtime was autocalculated
[ 1208.281948] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1208.483630] video4linux video1: frame start syncpt timeout!0
[ 1208.489655] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00004000
[ 1208.489705] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1208.489749] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1208.489845] vi 54080000.vi: cil_settingtime was autocalculated
[ 1208.489863] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1208.691718] video4linux video1: frame start syncpt timeout!0
[ 1208.697729] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1208.697779] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1208.697825] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1208.697973] vi 54080000.vi: cil_settingtime was autocalculated
[ 1208.697992] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1208.774807] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5
[ 1208.983353] video4linux video1: frame start syncpt timeout!0
[ 1208.989479] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1208.989529] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1208.989569] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1208.989661] vi 54080000.vi: cil_settingtime was autocalculated
[ 1208.989679] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1209.191523] video4linux video1: frame start syncpt timeout!0
[ 1209.197666] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1209.197716] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1209.197763] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1209.197968] vi 54080000.vi: cil_settingtime was autocalculated
[ 1209.197990] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1209.399478] video4linux video1: frame start syncpt timeout!0
[ 1209.405505] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00004000
[ 1209.405556] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1209.405591] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1209.405682] vi 54080000.vi: cil_settingtime was autocalculated
[ 1209.405700] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1209.607533] video4linux video1: frame start syncpt timeout!0
[ 1209.613561] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1209.613609] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1209.613654] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1209.613771] vi 54080000.vi: cil_settingtime was autocalculated
[ 1209.613790] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1209.815509] video4linux video1: frame start syncpt timeout!0
[ 1209.821536] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1209.821585] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1209.821629] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1209.821842] vi 54080000.vi: cil_settingtime was autocalculated
[ 1209.821893] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1210.023496] video4linux video1: frame start syncpt timeout!0
[ 1210.029526] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1210.029574] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1210.029617] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1210.029830] vi 54080000.vi: cil_settingtime was autocalculated
[ 1210.029881] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1210.231489] video4linux video1: frame start syncpt timeout!0
[ 1210.237510] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1210.237557] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1210.237601] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1210.237816] vi 54080000.vi: cil_settingtime was autocalculated
[ 1210.237868] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1210.275460] vi 54080000.vi: tegra_channel_error_status:error 2 frame 13
[ 1210.483712] video4linux video1: frame start syncpt timeout!0
[ 1210.489563] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1210.489588] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1210.489610] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1210.489689] vi 54080000.vi: cil_settingtime was autocalculated
[ 1210.489701] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1210.691475] video4linux video1: frame start syncpt timeout!0
[ 1210.697509] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1210.697559] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1210.697601] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1210.697819] vi 54080000.vi: cil_settingtime was autocalculated
[ 1210.697872] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1210.899477] video4linux video1: frame start syncpt timeout!0
[ 1210.905502] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1210.905552] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 1210.905596] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040040
[ 1210.905812] vi 54080000.vi: cil_settingtime was autocalculated
[ 1210.905864] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1211.107322] video4linux video1: frame start syncpt timeout!0
[ 1211.113472] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1211.113494] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1211.113511] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1211.113603] vi 54080000.vi: cil_settingtime was autocalculated
[ 1211.113620] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1211.315472] video4linux video1: frame start syncpt timeout!0
[ 1211.321508] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1211.321558] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1211.321600] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1211.321813] vi 54080000.vi: cil_settingtime was autocalculated
[ 1211.321865] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1211.523469] video4linux video1: frame start syncpt timeout!0
[ 1211.529479] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00004000
[ 1211.529530] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1211.529574] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1211.529782] vi 54080000.vi: cil_settingtime was autocalculated
[ 1211.529835] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1211.731476] video4linux video1: frame start syncpt timeout!0
[ 1211.737504] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1211.737552] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1211.737596] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1211.737806] vi 54080000.vi: cil_settingtime was autocalculated
[ 1211.737859] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1211.979476] video4linux video1: frame start syncpt timeout!0
[ 1211.985789] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1211.985806] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1211.985821] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1211.985982] vi 54080000.vi: cil_settingtime was autocalculated
[ 1211.986003] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1212.187448] video4linux video1: frame start syncpt timeout!0
[ 1212.193706] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1212.193725] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000000
[ 1212.193740] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00000000
[ 1212.193871] vi 54080000.vi: cil_settingtime was autocalculated
[ 1212.193890] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1212.395225] video4linux video1: frame start syncpt timeout!0
[ 1212.401482] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1212.401500] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1212.401517] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1212.401677] vi 54080000.vi: cil_settingtime was autocalculated
[ 1212.401695] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1212.603453] video4linux video1: frame start syncpt timeout!0
[ 1212.609713] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1212.609731] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1212.609747] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1212.609882] vi 54080000.vi: cil_settingtime was autocalculated
[ 1212.609900] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1212.811475] video4linux video1: frame start syncpt timeout!0
[ 1212.817401] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1212.817414] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1212.817426] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1212.817498] vi 54080000.vi: cil_settingtime was autocalculated
[ 1212.817510] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1213.019423] video4linux video1: frame start syncpt timeout!0
[ 1213.025448] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1213.025497] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1213.025543] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1213.025757] vi 54080000.vi: cil_settingtime was autocalculated
[ 1213.025811] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1213.227637] video4linux video1: frame start syncpt timeout!0
[ 1213.233671] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 1213.233722] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000002
[ 1213.233768] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00020020
[ 1213.233900] vi 54080000.vi: cil_settingtime was autocalculated
[ 1213.233920] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 1213.274744] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 29
[ 1213.285513] imx185 8-001a: imx185_power_off: power off
[ 1213.291001] imx185 8-001a: camera_common_dpd_enable: csi 4
[ 1213.296621] imx185 8-001a: camera_common_mclk_disable: disable MCLK
Used device tree NANO
 * Copyright (c) 2018-2019, NVIDIA CORPORATION.  All rights reserved.
 * more details.
#include <dt-bindings/platform/t210/t210.h>
	host1x {
		vi_base: vi {
			num-channels = <2>;
			ports {
				#size-cells = <0>;
				vi_port0: port@0 {
					reg = <0>;
					rbpcv2_imx185_vi_in0: endpoint {
						port-index = <0>;
						bus-width = <2>;
						remote-endpoint = <&rbpcv2_imx185_csi_out0>;
				vi_port1: port@1 {
					reg = <1>;
					rbpcv2_imx185_vi_in1: endpoint {
						port-index = <4>;
						bus-width = <2>;
						remote-endpoint = <&rbpcv2_imx185_csi_out1>;
		csi_base: nvcsi {
			num-channels = <2>;
			#size-cells = <0>;
				reg = <0>;
				ports {
					#size-cells = <0>;
						reg = <0>;
						rbpcv2_imx185_csi_in0: endpoint@0 {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&rbpcv2_imx185_dual_out0>;
						reg = <1>;
						rbpcv2_imx185_csi_out0: endpoint@1 {
							remote-endpoint = <&rbpcv2_imx185_vi_in0>;
			csi_chan1: channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					csi_chan1_port0: port@2 {
						reg = <0>;
						rbpcv2_imx185_csi_in1: endpoint@2 {
							port-index = <4>;
							bus-width = <2>;
							remote-endpoint = <&rbpcv2_imx185_out1>;
					csi_chan1_port1: port@3 {
						reg = <1>;
						rbpcv2_imx185_csi_out1: endpoint@3 {
							remote-endpoint = <&rbpcv2_imx185_vi_in1>;
	cam_i2cmux {
		i2c_0: i2c@0 {
				reg = <0x1a>;
				/* Clocks */
				clocks = <&tegra_car TEGRA210_CLK_EXTERN3>, <&tegra_car TEGRA210_CLK_EXTERN3>;
				clock-names = "extperiph3", "pllp_grtba";
				mclk = "extperiph3";
				devnode = "video0";
				* ==== Modes ====
				* phy_mode = "";
				* pix_clk_hz = "";
				* active_w = "";
				* active_h = "";
				* pixel_t = "";
				* line_length = "";
				mode0 { /* 3648x2304 */
					mclk_khz = "20000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "3648";
					active_h = "2304";
					gain_factor = "1";
					min_framerate = "100000"; /* 0.1 fps */
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						rbpcv2_imx185_dual_out0: endpoint {
							port-index = <0>;
							bus-width = <2>;
							remote-endpoint = <&rbpcv2_imx185_csi_in0>;
		i2c_1: i2c@1 {
			imx185_cam1: rbpcv2_imx185_e@1a {
				/* Clocks */
				reg = <0x1a>;
				devnode = "video1";
				* ==== Modes ====
				* phy_mode = "";
				* pix_clk_hz = "";
				* active_w = "";
				* active_h = "";
				* pixel_t = "";
				* line_length = "";
					mclk_khz = "20000";
					num_lanes = "2";
					tegra_sinterface = "serial_e";
					phy_mode = "DPHY";
					active_w = "3648";
					active_h = "2304";
					gain_factor = "1";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						rbpcv2_imx185_out1: endpoint {
							port-index = <4>;
							bus-width = <2>;
							remote-endpoint = <&rbpcv2_imx185_csi_in1>;
		f_number = "2.0";
		aperture = "0.0";
		num_csi_lanes = <4>;
		min_bits_per_pixel = <10>;
		modules {
				badge = "porg_front_RBPCV2";
				position = "front";
				orientation = "1";
					devname = "imx185 7-001a";
			cam_module1: module1 {
				badge = "porg_rear_RBPCV2";
				position = "rear";
				orientation = "1";
				cam_module1_drivernode0: drivernode0 {
					devname = "imx185 8-001a";
					proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/rbpcv2_imx185_e@1a";
				cam_module1_drivernode1: drivernode1 {
The datastream from the FPGA is 3648x2304 in RAW12, with 0.66 fps and 2 Lanes.
Can you give me any lead on what might be wrong with my NANO device tree ?
Best Regards
Looks like SOT error that could be the MIPI timing cause the problem.
Maybe adjust the settle time to try.
Thank you for your response. According to dmesg the settletime is currently auto calculated as 10. What time would you recommend ?
Below is from the L4T sensor programing guide.
THS settle time of the MIPI lane, in nanoseconds. Calculate the range of acceptable values with the formula:
85 ns + 6×*ui* < (*cil_settletime*+6) × (*lp_clock_period*) < 145 ns + 10×*ui*
Where:
* *lp_clock_period* is 1/(204 MHz).
* *ui* is the unit interval, equal to the duration of the HS state on the clock lane.If the value is 0, the driver attempts to auto-calibrate according to the `mclk_multiplier` parameter.
See the [MIPI Alliance Specification for D-PHY](http://bfiles.chinaaet.com/justlxy/blog/20171110/1000019445-6364593011828743047249885.pdf) for details.
We solved the Issue by adjusting the IMX219 instead of the IMX185 driver to our needs. Thank you for your time.
