From the documentation (User Guide — nsight-systems 2023.4.1 documentation), using GPU Metrics for Linux targets on x86-64 requires NVIDIA Turing architecture or newer. I am using a GeForce RTX 3060 on Ubuntu 20.04 with driver version 470.223.02, but I cannot use GPU Metrics. Why is that?
@1397921243, thank you for reporting this issue. Please also help confirm the version of Nsight Systems — are you using the latest 2023.4.1?
One of the common issues that you might face is a permissions issue. Please see https://developer.nvidia.com/ERR_NVGPUCTRPERM for more details. A quick way to confirm that is to try collecting from a command line:
- This should complain about the GPU not supported:
nsys profile --gpu-metrics-device=help
- This should succeed:
sudo nsys profile --gpu-metrics-device=help
Once this is confirmed, there are two ways to proceed:
- Use the CLI to collect GPU metrics
- Follow the instructions on https://developer.nvidia.com/ERR_NVGPUCTRPERM to enable non-root collection temporarily or permanently
It works,thank you so much!
