I have recently requested a license for PGI Accelerator Fortran/C/C++ Workstation, 018AL-WD-F, through nVidia OpenACC ToolKit program.
Currently I have installed the packaged on my computer running Ubuntu 15.04 64bit system. I have not been successful with the permanent license file I generated online. When I issue the pgfortran command, there would be an error prompt:
pgfortran: LICENSE MANAGER PROBLEM: No such feature exists.
Feature: pgi-f95-lin64
License path: /opt/pgi/license.dat:
FlexNet Licensing error:-5,357
For further information, refer to the FlexNet Licensing documentation, available at "www.flexerasoftware.com"
To debug the problem, I have requested to delete the previously created permanent license. After the old license was deleted, I created a new license using PGI’s online interface, and I did not change the default values showed up on the web page. I then placed the new license.dat in the pgi folder, changed the access privileges to 644. However this still did not work. I finally tried to use the 90 days trial license sent to me in email earlier, and everything worked fine.
I would appreciate if you could take a look at my account and advise on how I should modify the installation or the license file. Thanks!
