Here comes another problem after I installed the PGI workstation. I used the workstation to pgfortran a file while an error ouccured.
PGF90-S-0021-Label field of continuation line is not blank (temp.f: 1)
pgfortran: LICENSE MANAGER PROBLEM: Failed to checkout license
pgfortran: LICENSE MANAGER PROBLEM: This platform not authorized by license.
Feature: pgfortran
Platforms: win-acc <> unidev, v16.1, nv, lin-acc
License path: C:\Program Files\PGI\license.dat;C:\PROGRA~1\PGI/license.dat;
FlexNet Licensing error:-89,310
For further information, refer to the FlexNet Licensing documentation,
available at “www.flexerasoftware.com”.
It told me my platform has not be authorized by license, but in fact a license.dat file has exsited in the installation directory which was generated through the program PGILicForm.exe. What should I do?
Are you using the unidev license 7***39 ?
That is all I see connected to this web account.
If so, it is a Linux only license, and will not work on Windows.
If you are using a different PIN, let us know. You may want to
send the info to license@pgroup.com, for privacy.
Now I transform the develope platform to Linux(ubuntu 16.04 on virtual machine), and I found the original PIN of mine has been licensed, that might because I misused the license on Windows before.
Now when I run the PGI_license_tool on Linux it prompts:
“No seats are available for the specified license”
So could you regenerate a new license for me? Or is there any other solution to the problem?
