Hi, I have installed Omniverse in Windows,and I would like to use Isaac Sim for data generation. But even for the “simple_room” environment I can not get correct Sensor outputs:
Then, the generated data is not reasonable too:
I reinstalled the Isaac Sim, but the problem did not solved. I treid with Omniverse Code and there is no problem there. Therefore the problem is with the Isaac Sim itself.
Does anyone have the idea about the issue and how can I solve it?
