I need to create a lot of camera viewports, and each is associated with a different camera (so I can use syntheticDataHelper). However, when I create like 12-13 viewports, I get the following bug:
The same thing happens on both ubuntu and windows. It seems there is a max limit on the number of viewports I can create. Then I open the application to create viewports manually. I found out that the same thing happens. Is there a way to increase the number of viewports I can create, or is this not the best practice for large parallel image-based training?
Here is how I create viewports
viewport_handle = omni.kit.viewport_legacy.get_viewport_interface().create_instance()
new_viewport_name = omni.kit.viewport_legacy.get_viewport_interface().get_viewport_window_name(
viewport_handle
viewport_window = omni.kit.viewport_legacy.get_viewport_interface().get_viewport_window(viewport_handle)
viewport_window.set_active_camera(camera_path)
viewport_window.set_texture_resolution(*self.sensor_resolution)
viewport_window.set_window_pos(1000, 400)
viewport_window.set_window_size(400,400)
sd_helper = SyntheticDataHelper()
sd_helper.initialize(sensor_names=self.sensor_types, viewport=viewport_window)
In the documentation for Isaac gym, there is something like this:
self.gym.simulate(self.sim)
self.gym.fetch_results(self.sim, True)
self.gym.step_graphics(self.sim)
self.gym.render_all_camera_sensors(self.sim)
self.gym.start_access_image_tensors(self.sim)
Is there an equivalent version in Isaac sim?
