Issue with visualising Da Vinci's workshop sample projects
Hello all,
When I openm the Da Vinci’s project all the geometry is covered by it’s PROXY equalivent. Turning off Proxy from “Show by Purpose” menu does not change anything.
What is weird that the first time I opened the project everything seemed fine with only the Render geometry visible. I have no idea what happened…I did not update / reinstall USD Composer since then.
You may have FSD on. Fabric Scene Delegate. Try turning that off and see if that helps.
