Hello NVIDIA Community,
I am trying to use bandwidth control of k8s on the Jetson AGX Orin. However, the bandwidth control is ineffective because qdisc cannot be used. To use qdisc, I need to enable Network emulator (NETEM). Therefore, I am attempting to customize the kernel.
Now, I am encountering several issues while building the kernel for my Jetson AGX Orin 64GB Developer Kit. Here are the details of my setup and the problems I am facing:
Device Model: Jetson AGX Orin 64GB Developer Kit
Kernel Version: 36.3
Documentation Followed: Official NVIDIA documentation for kernel building Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation
Steps Taken:
I followed the official NVIDIA documentation to build the kernel.
In the .config file, I set Network emulator (NETEM) to Y.
zcat /proc/config.gz > .config
make menuconfig
After building the kernel, I replaced the Image file.
make ARCH=arm64
sudo cp $TEGRA_KERNEL_OUT/arch/arm64/boot/Image /boot/Image
I also replaced the dtb files and installed the modules.
sudo cp $TEGRA_KERNEL_OUT/arch/arm64/boot/dts/* /boot/dtb/
make ARCH=arm64 modules
sudo make modules_install
Issues Encountered:
Boot Issues:
After replacing the Image file and dtb files, and installing the modules, the device fails to boot from the SSD.
When I attempt to boot from the eMMC, it unexpectedly boots from the SSD.
NETEM Configuration:
Despite setting Network emulator (NETEM) to Y in the .config file, the setting does not take effect.
$ sudo zcat /proc/config.gz | grep CONFIG_NET_SCH_NETEM
CONFIG_NET_SCH_NETEM is not set
Request for Assistance:
Has anyone experienced similar issues with booting from SSD after kernel building? If so, what steps did you take to resolve this?
How can I effect that the NETEM configuration? Are there specific steps or additional configurations needed to make this work?
Any guidance or suggestions would be greatly appreciated. Thank you for your help!
Best regards,
Hitachi Astemo,Ltd.
Zhang Yuhang
