Jetson AGX Orin SD card booting failedA
I’m trying to boot the Agx orin board from SD card but unable to boot Successfully.
[ 11.176569] Freeing unused kernel memory: 3968K ±----------------------------+
[ 11.181275] Run /init as init process
[ 11.196730] Root device found: mmcblk1p1
[ 11.205091] Found dev node: /dev/mmcblk1p1
[ 11.386304] EXT4-fs (mmcblk1p1): recovery complete
[ 11.391257] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.542499] Rootfs mounted over mmcblk1p1
[ 11.551371] Switching from initrd to actual rootfs
[ 11.558034] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 11.565914] CPU: 1 PID: 1 Comm: chroot Not tainted 5.10.216-tegra #1
[ 11.572439] Hardware name: NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 6.0-37391689 08/28/2024
[ 11.581821] Call trace:
[ 11.584353] dump_backtrace+0x0/0x1e0
[ 11.588119] show_stack+0x30/0x40
[ 11.591520] dump_stack+0xf0/0x130
[ 11.595016] panic+0x1a4/0x394
[ 11.598159] do_exit+0xafc/0xb00
[ 11.601482] do_group_exit+0x4c/0xb0
[ 11.605151] __arm64_sys_exit_group+0x28/0x30
[ 11.609634] el0_svc_common.constprop.0+0x80/0x1d0
[ 11.614558] do_el0_svc+0x38/0xc0
[ 11.617969] el0_svc+0x1c/0x30
[ 11.621096] el0_sync_handler+0xa8/0xb0
[ 11.625044] el0_sync+0x16c/0x180
[ 11.628462] SMP: stopping secondary CPUs
[ 11.632735] Kernel Offset: 0x296889ae0000 from 0xffff800010000000
[ 11.639009] PHYS_OFFSET: 0xfffffbecc0000000
[ 11.643305] CPU features: 0x08040006,4a80aa38
[ 11.647781] Memory Limit: none
[ 11.650916] —[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]—
How did you prepare that image in the sdcard?
I have used the below command to flash into SD card
sudo ./flash.sh jetson-agx-orin-devkit mmcblk1p1 by following the link
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/IN/QuickStart.html
Are you sure you are referring to rel-36.2 document? What I saw from your log is you are using Jetpack5.
Yes I’m using rel-36.2 document only. above log file is flash from SDK manager which contains Jetpack5 and even though i got the same log when i followed from Document.
So which jetpack version is in use exactly?
Jetson6.2
Your whole comment out of logic. Do you understand what yourself is talking about?
You just told me you are using sdkmanager to flash Jetpack5 but you just again tell me you are using Jetpack6.2
