Greetings,
I am contacting you to ask you for support about the documentation related to one of the NVIDIA Jetson modules, the Jetson AGX Orin 64 GB Developer kit (P3701-0005 moduleP3737-0000 carrier board).
I’m trying to flash the Jetson on an external NVMe 3 Gen x4 to expand the storage capacity. I set the module in recovery mode following the official NVIDIA page instructions, then I tried using the Nvidia SDK Manager Package and Linux Terminal commands using ./flash_jetson_external_storage.sh from GitHub - jetsonhacks/bootFromExternalStorage: Shell scripts to setup a NVIDIA Jetson AGX Xavier, Xavier NX, AGX Orin, or Orin Nano Developer Kit to boot from external storage. repository. It has taken a long time and I still receive the same errors for both SDK manager and Linux Terminal (I attached images).
Is there a command that I can use on the module to prepare it for flashing it from an external NVMe? How can I troubleshooting this issue?
Thank you for your attention; I am waiting for your answer.
Best regards.
