Issues Using M10 for Training
I passed one of my GPUs through to a ubuntu 20.04 VM via Proxmox.
Installed latest nvidia driver on host and guest.
Installed nvidia runtime container.
Created Docker with base of: FROM nvidia/cuda:11.7.1-cudnn8-devel-ubuntu20.04
Ran training script.
Got this error:
023-01-05 14:09:36.390622: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:981] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2023-01-05 14:09:36.390766: I tensorflow/core/common_runtime/gpu/gpu_process_state.cc:222] Using CUDA malloc Async allocator for GPU: 0
2023-01-05 14:09:36.390889: F tensorflow/core/common_runtime/gpu/gpu_cudamallocasync_allocator.cc:160] TF_GPU_ALLOCATOR=cuda_malloc_async isn't currently supported on GPU id 0: Possible causes: device not supported (request SM60+), driver too old, OS not supported, CUDA version too old(request CUDA11.2+).
run.sh: line 1: 32 Aborted (core dumped) python3 run.py
Output of nvidia-smi:
Thu Jan 5 14:10:18 2023
| NVIDIA-SMI 525.60.13 Driver Version: 525.60.13 CUDA Version: 12.0 |
| | | MIG M. |
| 0 Tesla M10 On | 00000000:01:00.0 Off | N/A |
| N/A 46C P8 8W / 53W | 0MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Anyone in the know? Could use a hint here.
Unfortunately it looks like your M10 is too old:
The M10 is SM50.
