I was completely stuck at the step while building jetbot ros_deep_learning. I googled everything, hardly find the right solution to overcome the issue…Please, anyone can give me a heads up? much appreciated.
The command is:jetbot@jetbot:~/workspace/catkin_ws$ catkin_make
That is strange, as I re-downloaded here and they compiled and installed OK.
So this error seems to indicate that your ros_deep_learning repo is up-to-date, but perhaps your jetson-inference needs updating. Can you try re-installing jetson-inference (master branch) if you haven’t already?
Neither jetson-inference or ros_deep_learning depend on Qt4 anymore, as you can see from ros_deep_learning/CMakeLists.txt it is commented out. Can you confirm that your CMakeLists.txt shows the same?
Thank you very much.Today I delete the whole directory “catkin_ws”,and recloned the package.It’s all working well. But when I run the “roscore” and “rosrun jetbot_motor” ,another problem happened,just like the following:
jetbot@jetbot:~$ rosrun jetbot_ros jetbot_motors.py
File “/home/jetbot/workspace/catkin_ws/src/jetbot_ros/scripts/jetbot_motors.py”, line 75, in
motor_driver = Adafruit_MotorHAT(i2c_bus=1)
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py”, line 231, in init
self._pwm = PWM(addr, debug=False, i2c=i2c, i2c_bus=i2c_bus)
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py”, line 59, in init
self.setAllPWM(0, 0)
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py”, line 95, in setAllPWM
self.i2c.write8(self.__ALL_LED_ON_L, on & 0xFF)
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_GPIO/I2C.py”, line 114, in write8
self._bus.write_byte_data(self._address, register, value)
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_PureIO/smbus.py”, line 256, in write_byte_data
self._device.write(data)
IOError: [Errno 121] Remote I/O error
and it is the same error with “pioled” too,as the following:
jetbot@jetbot:~$ rosrun jetbot_ros jetbot_oled.py
File “/home/jetbot/workspace/catkin_ws/src/jetbot_ros/scripts/jetbot_oled.py”, line 43, in
disp.begin()
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_SSD1306/SSD1306.py”, line 148, in begin
self._initialize()
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_SSD1306/SSD1306.py”, line 292, in _initialize
self.command(SSD1306_DISPLAYOFF) # 0xAE
File “/home/jetbot/.local/lib/python2.7/site-packages/Adafruit_SSD1306/SSD1306.py”, line 129, in command
self._i2c.write8(control, c)
When I use the command i2c detect,there is a warning:
jetbot@jetbot:~/workspace/catkin_ws$ i2cdetect -y 1
Warning: Can’t use SMBus Quick Write command, will skip some addresses
0 1 2 3 4 5 6 7 8 9 a b c d e f
00:
10:
20:
30: – – – – – – – –
40:
50: – – – – – – – – – – – – – 5d – –
60:
70:
Hi xiaohuih, unfortunately I am unsure what the i2c issue you face is, as I don’t see this problem here with my JetBot.
Is this a JetBot that you sourced the parts for yourself, or did you order it from one of these vendors?
If you use the default JetBot software from https://github.com/nvidia-ai-iot/jetbot, do you see the i2c problem? If so, maybe best to double-check the wiring.
Yes,I ordered it from Sparkfun,https://www.sparkfun.com/products/15365,which is SparkFun JetBot AI Kit.The wield thing is that both two jetbot had been well at the command “rosrun jetbot_ros jetbot_motors.py” before,but now they do not response to the command and the reminder is the same "IOError: [Errno 121] Remote I/O error "
Hi, I bought it from Sparkfun also. The command rosrun jetbot_ros jetbot_camera works. It is publishing the camera frames. However when I run
rosrun jetbot_ros jetbot_motors.py and
I get similar errors, respectively.
File “/home/jetbot/workspace/catkin_ws/src/jetbot_ros/scripts/jetbot_motors.py”, line 5, in
import qwiic_scmd
ImportError: No module named qwiic_scmd
and
File “/home/jetbot/workspace/catkin_ws/src/jetbot_ros/scripts/jetbot_oled.py”, line 5, in
import Adafruit_SSD1306
ImportError: No module named Adafruit_SSD1306
Sparkfun’s jetbot_ros has updated the jetbot_motors.py so instead of Adafruit_MotorHAT, the code imports qwiic scmd
I tried using the following in the .bashrc
export LD_LIBRARY_PATH=/usr/local/lib:/opt/ros/melodic/lib
It did not work.
I can see both the qwiic modules (oled and scmd) on i2c bus
jetbot@jetson:~$ i2cdetect -r 1
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-1 using receive byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – 3d – –
40: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
