In the folder: Linux_for_Tegra/rootfs/boot/kernel/dtb
there are several dtb files.
Which dtb should be modified to disable MMU ? How ?
After burning the new dtb, how can I make sure that SMMU is disabled ?
In a previous thread, the file: tegra186-quill-p3310-1000-c03-00-base.dtb is used
But I do not have this file.
The command: sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
is used to burn the new dtb.
Should I place the modified dtb in it’s same original location ?
