Hello, I am working with TX2i module and Jetpack 4.2 (can’t use newer). Board is successfully flashed and I am now trying to install target components via sdkmanager:
But I get errors:
19:33:12 INFO: OpenCV on Host - host: (Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 283245 files and directories currently installed.)
19:33:12 INFO: OpenCV on Host - host: Preparing to unpack …/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb …
19:33:12 INFO: OpenCV on Host - host: Unpacking libopencv (3.3.1-2-gb3f86dcd5) …
19:33:12 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
19:33:12 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 2…
19:33:12 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 2…
19:33:12 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 2…
19:33:12 INFO: OpenCV on Host - host: trying to overwrite ‘/usr/bin/opencv_version’, which is also in package libopencv-dev 3.2.0+dfsg-4ubuntu0.1
19:33:12 INFO: OpenCV on Host - host: /home/puksec/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb
19:33:12 ERROR: TensorRT on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
19:33:12 : TensorRT on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb failed, retrying 2…
19:33:12 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb
19:33:13 INFO: TensorRT on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb
19:33:13 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb
19:33:13 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb
19:33:13 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
19:33:13 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 3…
19:33:13 INFO: OpenCV on Host - host: exec_command: sudo apt-get check
19:33:13 INFO: OpenCV on Host - host: Reading package lists…
19:33:13 ERROR: TensorRT on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
19:33:13 : TensorRT on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb failed, retrying 3…
19:33:13 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 3…
19:33:13 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 3…
19:33:13 INFO: OpenCV on Host - host: Building dependency tree…
19:33:13 INFO: OpenCV on Host - host: Reading state information…
19:33:13 INFO: OpenCV on Host - host: exec_command: dpkg-query -W -f=’${db:Status-abbrev} ${Version}’ libopencv
19:33:13 INFO: OpenCV on Host - host: [ NV_OPENCV_HOST_COMP Install took 4s ]
19:33:13 ERROR: OpenCV on Host - host: command terminated with error
19:33:13 SUMMARY: VisionWorks on Host - host: Depends on failed component
19:33:13 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb
19:33:14 INFO: TensorRT on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb
19:33:14 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb
19:33:14 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
19:33:14 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 4…
19:33:14 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb
19:33:14 ERROR: TensorRT on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
19:33:14 : TensorRT on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb failed, retrying 4…
19:33:15 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
19:33:15 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 4…
19:33:15 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 4…
19:33:15 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb
19:33:15 INFO: TensorRT on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb to /home/puksec/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb
19:33:15 ERROR: cuDNN on Target - target: download failed
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2022, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
